Islander 36 electric inboard? diy - Page 2 - SailNet Community
 9Likes
post #11 of 46 Old 10-21-2013
One of None
deniseO30's Avatar
Re: Islander 36 electric inboard? diy
Not to be a downer.. but I think this idea will come to a screeching stop when the costs start to tally up in comparison to a diesel http://www.mastervolt.com/marine/
My last project!
deniseO30 is offline
post #12 of 46 Old 10-21-2013 Thread Starter
christian.hess's Avatar
that is a top of the line australian I beleive direct drive hybrid system...that has about as much in common with a forklift motor or similar system as a swan to a macregor...
my issue has been so far determining what off the shelf components can I use to install in my boat. a golf cart system would be nice and dandy for me.
used even better!
christian.hess is offline
post #13 of 46 Old 10-21-2013
Christian,
Electric drives are very doable, but a 10kw motor isn't likely to be big enough. A 35' boat is going to need a lot more HP than this in anything other than dead calm days, when going sailing seems pretty pointless. Figure you will need a 25hp minimum, and ideally 40.
Greg
Stumble is offline
post #14 of 46 Old 10-21-2013 Thread Starter
the palmer p60 a great engine btw with one big drawback(exhaust manifold) is 22hp at the crank...10 or barely more at the prop, 2 blade...
stock...
I wish not to make this a motorsailor...I was trying to ask specific questions, hopefully from that member who did so on his islander 36...he did so using forklift motors or similar...
I have no need or want a 40hp diesel...I found my 2gm yanmar to be plenty enough power and TROUBLE on my old h28 that only wieghed a ton less or so than my current boat...
The issue I have is that the forums seem to have a lot of unfinished threads...leaving more questions than answers sometimes...
anybody done an install in a remote location...using a weird combo of motor and controller etc..?
thanks
post #15 of 46 Old 10-21-2013
there are some commercial solutions, like
Products | GreenStar Marine
Their largest engine has been used on boats up to 40 ft.
Major drawback of electrical engines is the difficulty and limitation of energy storage. This leads to a limited range, and to a somewhat lower power compared to diesels. In itself this is not any show stopper as long as one is aware of it - you state you only wnat to use the engine when mooring etc - should work fine then.
/J
Jaramaz is offline
The Following User Says Thank You to Jaramaz For This Useful Post:
christian.hess (10-21-2013)
post #16 of 46 Old 10-21-2013
One of None
deniseO30's Avatar
the motor is only one part of a complex system of very large cables. (talking 400 amps and more) power source, batteries alone would sink the boat, unless you could source the new type, how to recharge (generator) , a controller. and more.
I realize this is an outboard but Myth busters Jamie is spot on what your talking about.
My last project!
post #17 of 46 Old 10-21-2013
One of None
deniseO30's Avatar
more;
My last project!
post #18 of 46 Old 10-21-2013
One of None
deniseO30's Avatar
And the best for last! LOL in a sailboat! note the size of those cables! LOL
My last project!
post #19 of 46 Old 10-21-2013 Thread Starter
thanks for that last vid denise
christian
post #20 of 46 Old 10-21-2013 Thread Starter
I meant second to last
I have seen those vids before...except for the forklift one...
I guess Im not asking wether its feasible...Im a fan and have done a lot of research...I guess I would lke to know specifics...
any islander 36 owners with electric propulsion...?
Tags
electric inboard , islander 36 , propulsion
2 stroke inboard PeterSailer General Discussion (sailing related) 26 11-21-2013 11:47 AM
Islander 28 vs Islander Bahama 30 vs Irwin Cititation 34 twelch Boat Reviews 42 05-28-2013 10:17 AM
Electric hybrid Inboard Vs Diesel SirRedemption General Discussion (sailing related) 25 02-18-2013 01:59 PM
Islander 30 seeking other Islander 30 people Creager Introduce Yourself 12 01-06-2013 02:29 PM
Budget Electric inboard bmacfarquhar Gear & Maintenance 16 02-23-2010 07:54 PM
