Spreaders for Pearson 10M - SailNet Community
post #1 of 5 Old 10-20-2013 Thread Starter
I bought a 1977 Pearson 10M this past summer and one of the the riggers who looked at it was concerned that the spreaders were too loose. They are attached to a housing secured to the mast by one bolt each and they have significant play fore and aft.
The halyards also rub along the forward side of the spreaders which has chafed the halyards to the point of needing replacement. The front of the spreaders shows where the halyards have rubbed along them, wearing grooves in some places - which indicates this 10M has been this way for a long time.
Any thoughts or suggestions? Is this something I need to remedy, or a characteristic of the boat - and I should simply plan on keeping up with the cafe?
Many thanks
CaptainKelly is offline
post #2 of 5 Old 10-20-2013
Re: Spreaders for Pearson 10M
Are your halyards 'chafing' during storage or during use? I'd expect a P10M to have internal halyards, which would mean they chafe when stored at the mast base.. if so you can minimize the issue by storing the halyards on the toerails away from the mast and rig when not sailing.
One would think the spreader root attachments were 'standard' for the boat.. some bendy rigs need that spreader mobility to absorb the mast bend, on a P10M that's also something you might expect. But I'd also expect a rigger to recognize that if it's 'normal'.. maybe get a second rigger's take on it all?
Faster is online now
post #3 of 5 Old 10-21-2013 Thread Starter
Hey Faster -
My halyards are external and yes, you're right about the chafing happening while at rest. And I do pull them away from the mast because the sound is, well, enough for me.
I guess my real concern, which your reply helped clarify for me, is the flexibility in the spreaders. One rigger was horrified, the other nonplussed but wanted a beefier bolt as the attachment point. I do have a third coming out this week.
Thank you for your reply and taking the time to share your thoughts - they helped me think about it somewhat differently.
Best
post #4 of 5 Old 10-21-2013
DrB
I have a 10M
Mine is a 1979. It has two bolts for each spreader. Mine wiggle very little. The halyards do rub, but pull them away and your fine.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
The Following User Says Thank You to DrB For This Useful Post:
CaptainKelly (10-23-2013)
post #5 of 5 Old 10-23-2013 Thread Starter
Two bolts for each - OK... Yes - mine seem to pivot on that single bolt.
Nice to meet another 10M captain
Spreaders - O'Day 272 LE Deke Gear & Maintenance 1 08-14-2012 12:50 PM
Cal 2-27 Spreaders SteveMartin Gear & Maintenance 5 07-11-2009 10:43 PM
spreaders Leland Gear & Maintenance 22 05-20-2008 07:24 PM
First 285 Spreaders rhaley Beneteau 1 11-23-2007 06:11 PM
Spreaders sailaway21 Gear & Maintenance 7 04-03-2007 08:26 PM
