Best hose for holding tank vent pipe? - SailNet Community
post #1 of 10 Old 10-21-2013 Thread Starter
A couple of months ago I replaced the holding tank vent pipe - and foolishly used PVC. It was fine for a while, but now it's permeating like crazy. The smell is horrible.
So what's the best hose to use? I'm thinking of just using the Trident sanitation hose, a little overkill I know. Or is it?
MarkSF is offline
post #2 of 10 Old 10-21-2013
Re: Best hose for holding tank vent pipe?
Trident Sanitation Hose would not be over kill if it is available in the size you need. What size is your vent?
hopcar is offline
post #3 of 10 Old 10-21-2013 Thread Starter
The fittings at both ends are 3/4". I'd have to enlarge a few holes as the pipe passes through several bulkheads - not a problem though.
MarkSF is offline
post #4 of 10 Old 10-21-2013
At the least, I would use proper sanitation hose. When the boat heels, its not uncommon for some effluent to wash up into the vent hose.
Additionally, it's recommended that a vent line be at least 1". Air exchange is one of the key requirements to keep a tank from smelling badly. Odor is caused by anaerobic bacteria that only live in low Ox environments.
Jeanneau 54DS
Minnewaska is offline
post #5 of 10 Old 10-21-2013
pdqaltair's Avatar
Shields white sanitation hose is a good choice for vents. Very few problems in this application (but not so much for liquid hose use).
Trident 101/102 is available in 1" (Defender). Not available in 3/4". Other premium hoses (Dometic, Shields, Raritan) are not available in smaller sizes.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #6 of 10 Old 10-21-2013
Maine Sail's Avatar
After some long discussions with Trident I began using their wet exhaust rated hose. They claim it is the same construction only less thick than #101. I have some out there at 7 plus years and no odor....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #7 of 10 Old 10-21-2013
overbored's Avatar
I use Trident XHD hose. it comes in 3/4"
"GOLD RUSH" PRINDLE 16
overbored is online now
post #8 of 10 Old 10-22-2013
chef2sail's Avatar
TRident green stripe
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #9 of 10 Old 10-22-2013
pdqaltair's Avatar
My boat was piped with Trident WEH and it permiated something terrible by year 10 (when I bought the boat). While it is a good vent choise, it certainly isn't like 101/102.
Choises in smaller sizes certainly are limited.
post #10 of 10 Old 10-22-2013
Maine Sail's Avatar
By year ten, not bad...........!!!
I have white PVC "sanitation labeled" hose permeating by year two!!!!
As I mentioned the WEH is not the same thickness of 101 and will not resist odors as long, but unless you know of better option in sizes other than 1" and 1.5" then we are very limited in our choices..
I've tried everything under the sun for the odd vent sizes and the WEH seems to hold up best... Actually for one vent I found a low odor permeation diesel hose in 5/8" and that one has not let a scent out either.... I have tried nearly every brand of white PVC hose and they all stink IMHO.....
Just did my first job with butyl flex this summer so time will tell but I do like how easy it is to work with...
______
Clearing the Holding Tank Vent Hose brucemoody Gear & Maintenance 10 08-14-2012 07:28 PM
PVC Pipe for a holding tank? kwaltersmi Gear & Maintenance 25 11-11-2010 05:21 PM
Holding Tank Vent tdw Gear & Maintenance 21 09-02-2010 10:32 PM
holding tank vent tugboatdon Gear & Maintenance 11 05-21-2010 12:39 PM
Holding tank vent.. groundhog Gear & Maintenance 9 06-18-2007 08:37 PM
