I'm leaving my W 27 in the water for the winter. I plan on attending to various projects while she's sitting mostly unused during the off-season.
While I don't specifically "live-aboard", I do/have spent nearly half my time aboard. I have used the head once in 6 months, as there's facilities ashore. I empty and change out/clean the fresh water tankage every two-three weeks.
I's like to have all the systems available during down time; but am loathe to come aboard to find frozen and leaking pipes. Is there a "best" way to partially winterize a boat?
The Beta20 has it's own supply of anti-freeze; but the water jacket/heat exchanger is fed by the thru hull and impeller. Then three's the matter of the water muffler and exhaust lines to be dealt with. While I don't have specific need to run the engine while there's snow falling, the option to be able to take advantage of a nice winter's day to sail does have appeal WITHOUT having to go thru a complete commission/decommission each time! :grrr:
*IF* II decide to close her down completely; what's the best way to freeze-proof the thru hulls? Rubber plugs from the outside and fill the lines down to the fittings with anti-freeze?. Fill down to the closed valves?
I plan to run a small heater when aboard and a bilge heater (60 w bulb?) when not there. 1500 w is all that's needed to keep the interior warm enuff for me. I plan on tenting it over and working topside occasionally utilizing a propane torpedo heater to take of the frost (only topside, with venting, of course!).
What's the consensus of those staying in the water over the cold times?
TAI,
Paul
TAI,
Paul
