Honda 9.9hp Outboard Won't Start - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 10-22-2013
midlife crisis member
AllThumbs's Avatar
Re: Honda 9.9hp Outboard Won't Start
Sounds like it's not in neutral. No need to check the spark if the motor isn't turning when you pull the rope.
I sail.
AllThumbs is offline
post #12 of 23 Old 10-22-2013
Take the cover off. On the top of the engine there's the carburetor
Look carefully for a small shiny brass screw.
Carefully remove the screw being extremely careful NOT to drop anything!
On the bottom there's a tiny, I mean tiny hole.
Take a fine wire and clean out that hole.
Replace and I believe it will start.
dick
Flybyknight is offline
post #13 of 23 Old 10-22-2013
Dave_E's Avatar
Originally Posted by themerryonion View Post
Thanks, everyone. It's a pull starter, and we hear a click in the engine when we pull it. I know some of you said that's not possible, but that's what it sounds like. No turning over, as I said. I'll probably check the spark plugs and clean the carburetor and get new fuel (pretty sure it's not an ethanol blend).
Hi Onion,
Not to mean you don't hear a "click". If you hear it... it's there. But those of us that know outboard engines, are visualizing something else/ Thanks for the clarification of "pull start". You will be bombarded with knowledge and swags from the most experienced to the least on a forum such as this. Without going to the shop... it's got to have: air, gas and spark. When you know you have those 3 and she won't run, then it's a carb most likely.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #14 of 23 Old 10-23-2013
Does the pull cord come out, about a foot or so when you pull it? If not, there is an interlock that prevents that if not in neutral. We have a Tohatsu 6HP 4 stroke and the shift lever has to be in EXACTELY the right spot to allow the cord to be pulled through.
If the engine is "pulling through", with the pistons cycling properly, suggest you re-visit some of the prior posts.
Paul T
dabnis is offline
post #15 of 23 Old 10-24-2013
Brewgyver's Avatar
If you're at a marina, ask a dock neighbor for help, many if not most boaters have at least some experience with small outboards. Also, read the manual. If you don't have one, find the Serial Number on your Honda and down load it here
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #16 of 23 Old 10-24-2013 Thread Starter
Unfortunately, we're anchored. But a guy who's been giving us informal lessons is going to take a look on Monday. I'll let you know what the verdict is, just in case anyone else has a similar issue.
EDIT: Did read through the manual thoroughly. Not much help, in this case.
themerryonion is offline
post #17 of 23 Old 10-25-2013
Mermaid Hunter
SVAuspicious's Avatar
Holla,
Sorry for your issues.
I have a Honda 9.9 with both electric and pull start. Frankly the pull start puts more energy into starting the engine than the electric does so as long as you don't have arthritis or bursitis or other physical issues the pull start is fine.
The Honda carbs are *extremely* sensitive to ethanol. There are several issues. First there is phase separation in older gas - that means the ethanol separates from the gas; the ethanol is corrosive and erodes the inside of the fuel line and leads to tiny particles clogging up the carb jets. Ethanol is also hydrophylic and sucks water right out of the air, leading to additional corrosion in the fuel system and the accumulation of water in the fuel tank.
Given you description I would haul your fuel tank ashore and dump it in a hazmat tank. Get new fuel. Drain your fuel line and carb bowl. Rebuild (sorry) the carb. Start over with clean fuel and the engine should start.
Moving forward, when you are done with the engine, every single time, remove the fuel line from the engine and let the engine run out of gas. Make sure you close the vent on the tank.
SVAuspicious is offline
post #18 of 23 Old 10-25-2013
themerryonion,
Catalina is a great choice for your first sailboat.
I bought a Catalina 25 with a 9.9 outboard and had problems with the carburetor.
I tried fixing the problem myself and ran into issues because the jets in the carburetor are so small.
My suggestion is to take it to a marine mechanic and spend the money to get it diagnosed and fixed up accordingly.
I spent $200 to have the carburetor overhauled and now it runs like new.
Once you do get it running make sure to add STABIL fuel treatment to each tank.
Also, disconnect your fuel line and let the motor idle until it runs out of gas.
These two practices will save you from issues in the future.
All the best.
Mr. Moon
magnolia_moon is offline
post #19 of 23 Old 10-25-2013
If all this info doesn't lead to a start possibly a kill switch failure. A bit of salt crystal grounds the spark. Was a common problem with older Hondas
Capt Len is offline
post #20 of 23 Old 06-08-2015
My 2005 9.9 hp honda outboard is not starting.The following has been done, clean gas w/ no ethanol, carburetor has been dipped and thoroughly cleaned. kill swich has been chek out and spark plugs have spark. I am not sure what is left to check. Does this particular model have computer andif so could this b the problem. Any help would be appreciated.
dandy dan is offline
Tags
engine trouble , engine won't start , honda outboard
Brand new Honda 5HP Outboard won't start - should I switch mfg? FishDragon Outboard 24 08-16-2014 03:18 PM
Any Honda Outboard Experts? Quickstep192 Gear & Maintenance 4 05-09-2007 05:22 PM
Parts for Honda 100 9.9HP outboard monroe Gear & Maintenance 1 08-16-2006 03:23 AM
Honda Outboard Motor xenetia Gear & Maintenance 0 04-19-2001 02:50 PM
Honda Outboard GGartin Gear & Maintenance 0 01-14-2001 05:14 PM
