Pedestal Adapter Plate Removal - SailNet Community
 1Likes
  • 1 Post By twomikes
post #1 of 8 Old 10-23-2013 Thread Starter
On my binnacle is this Pedestal Adapter Plate which holds the Gemini compass. I removed the compass, but to replace the throttle cable I also need to remove this plate. There are not any bolts accessible from what I can see, only small slots in this plate, but not sure what they are for. I've tried twisting, poking, cursing, but no joy. So, any suggestions on how to get this plate off the binnacle to access the throttle cable? It looks like part #36 in the attached compass schematic.
twomikes is offline
post #2 of 8 Old 10-24-2013
no longer reading SailNet
Alex W's Avatar
Re: Pedestal Adapter Plate Removal
The plate should be able to just be pulled up at this point. The only securing bolts would be the 4 threaded rods, and they appear to just running through the plate, not really connected to it.
Have you used a knife to cut all of the sealant between this plate and the shifter/throttle housing below it?
Alex W is offline
post #3 of 8 Old 10-24-2013 Thread Starter
Thx, its on really tight, so perhaps being held on by corrosion. I'll try a "persuading" tool to loosen things up.
twomikes is offline
post #4 of 8 Old 10-26-2013 Thread Starter
Success....
jimgo likes this.
twomikes is offline
post #5 of 8 Old 10-26-2013
Alex W's Avatar
Interesting setup on your boat with the studs. On my boat extra long screws go through the plate and down to threaded holes at the bottom of the shifter part of the pedestal. On yours it looks like the bolts come up from the top section of the shifter part and are held in place with nuts.
What holds the shifter/throttle part onto the pedestal? It is just sealant?
While you are in there I suggest lubing the main wheel bearings and chain as well. It made a huge difference in feel and rudder feedback on my boat.
Alex W is offline
post #6 of 8 Old 10-26-2013 Thread Starter
The plate is held on to the pedestal by corrosion and rust!!! It just slides over the four bolts, that are mounted to the pedestal.
I was thinking of lubing the chain, etc. Any recommendations on type of lube? As you can tell, I am brand new to the boating scene.
twomikes is offline
post #7 of 8 Old 10-26-2013
Alex W's Avatar
No, I mean the section below what you removed. The Edson pedestal is modular, and the part holding your shift and throttle levers is a module that is sitting above the base section of the pedestal (where the steering gear is). Those two parts should be bolted together, but it looks like they aren't.
A teflon dry lube like "super lube" works pretty well.
Alex W is offline
post #8 of 8 Old 10-28-2013 Thread Starter
Yes there are two bolts holding the top collar onto the pedestal. I was informed this is actually a Cinkel, vice Edson, pedestal. Here is a drawing:
twomikes is offline
Edson wheel removal from pedestal ambianceack Gear & Maintenance 7 04-22-2013 03:37 PM
mast deck hinge plate and halyard organizer plate on spirit 23 Southron Spirit North American Yachts 4 03-31-2012 06:59 PM
15/20 amp to 30 amp adapter itsaboat Electrical Systems 1 12-28-2011 12:46 AM
Chain plate removal? Ajax_MD Gear & Maintenance 8 11-16-2010 07:14 PM
Wiring GPS: pedestal or pedestal guard? geary126 Gear & Maintenance 14 05-17-2007 03:43 PM
