Inline 3 way wire connector? - SailNet Community
post #1 of 6 Old 10-24-2013 Thread Starter
I usually use Ancor connectors, however, I am looking for an inline application. Any recommendations? Heat shrink not needed, strength preferred.
thanks,
gary
SantaAna12 is offline
post #2 of 6 Old 10-24-2013
Brewgyver's Avatar
Re: Inline 3 way wire connector?
What is the application? Electrical or electronic? What is the load?
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #3 of 6 Old 10-25-2013
Puget Sound Pounder
kellysails's Avatar
Like this you mean? It is ancor
kellysails is offline
post #4 of 6 Old 10-25-2013
mitiempo's Avatar
I am not crazy about those Ancor connectors - it is hard to cover the exposed section. My choice would be a terminal block, not inline though. Probably best to have connections that are solidly mounted in any case. If it has to be inline a proper crimped connection with heatshrink is a good choice.
Brian
mitiempo is offline
post #5 of 6 Old 10-26-2013
Puget Sound Pounder
kellysails's Avatar
I agree. I've only used this connector once and I was not that pleased with the end result. Not sure why they don't put insulation over that exposed section.
post #6 of 6 Old 10-26-2013
Maine Sail's Avatar
For me it is not really the lack of insulation, that can be dealt with, but the grommet that holds it all together. They can tend to loosen over time, especially within the corrosive marine environment, and this creates high resistance...... A set screw on a terminal block is a considerably more robust connection...
On occasion, based on the particular circuit, I will crimp two wires into one end of a step-down butt connector. The nominal OD size of these two wires must be within the working crimp range of the butt splice. Too small and they can fail, too large and this can also fail and result in an over-crimp.
That said two wires into a butt splice are nearly impossible to seal, and I prefer heat shrink crimps, so I rarely do this unless there is really no other option. I have never, and will never, install a three-way ring like shown above.....
IMHO those are almost as bad as Scotchlok's
______
-Maine Sail / CS-36T
Maine Sail is offline
Raymarine transducer sense wire (-RAYA 7pin connector) Alex W Electronics 7 03-11-2013 07:45 PM
SSB wire antenna to antenna feed-line connector scud Electronics 0 09-24-2012 08:50 AM
12v inline pump before the filters? Jetexas Diesel 5 05-29-2012 02:46 PM
Connector for running a wire through the deck arf145 Gear & Maintenance 8 01-29-2010 05:11 PM
Best connector/fitting to run speaker wire through deck? josrulz Gear & Maintenance 5 01-03-2010 09:50 PM
