Whisker Pole - SailNet Community
post #1 of 6 Old 10-24-2013 Thread Starter
Whisker Pole
Hello. I'm looking to purchase a whisker pole for my 27 ft Columbia. Can anyone tell me the minimum to maximum telescopic length I need and what size of tubing should I be getting and anything else I need to be aware of . Thanks
weephee is offline
post #2 of 6 Old 10-24-2013
Remember you're a womble
PaulinVictoria's Avatar
Re: Whisker Pole
Depends on the size of your genoa(s), what do you have?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #3 of 6 Old 10-25-2013
overbored's Avatar
Re: Whisker Pole
7 to 15 ' by 2" will do for most 26' to 28' boats
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 6 Old 10-25-2013
Re: Whisker Pole
All the information for properly sizing a whisker pole can be found at forespar.com
In summary you need a couple of measurements one is the foot of the head sail and the other is the distance from the bow of the boat to the mast.
ambianceack is offline
post #5 of 6 Old 10-25-2013
Old as Dirt!
svHyLyte's Avatar
Re: Whisker Pole
Assuming your J dimension is about 12' a Forespar HD 7-15, #407101 will do nicely. As noted previously (above) see the Forespar Whisker/Spinnaker Guide
svHyLyte is offline
post #6 of 6 Old 10-25-2013 Thread Starter
Re: Whisker Pole
Thanks for the replies
weephee is offline
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Use of whisker pole. flyingwelshman Learning to Sail 10 06-30-2011 05:10 PM
Whisker pole jakesokol General Discussion (sailing related) 9 06-28-2011 03:22 PM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
