Styrofoam everywhere! - SailNet Community
 1Likes
  • 1 Post By CanadianNorth
post #1 of 8 Old 10-25-2013 Thread Starter
frscott's Avatar
Well i have started to clean out my new purchase (MacGregor 25) and as i have started to get into some of the holds, I find large quantities of chopped up Styrofoam. Asking my ex-navy friends, they say it is to help with buoyancy. I think that the displacement and buoyancy of the boat will not be helped with Styrofoam inside the hull, unless it is to fill compartments so nobody fills them with heavy stuff.
Overall question, why is it there and can I take it out???
Thanks
Scott
frscott is offline
post #2 of 8 Old 10-25-2013
CanadianNorth's Avatar
Re: Styrofoam everywhere!
Thanks
Scott
It's there in case you fill with water.
Sent from my iPhone using Tapatalk - now Free
___________________
High Hopes
1979 Glastron Spirit 28, Hull #28.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off your bowlines. Sail away from safe harbor. Catch the trade winds in your sails. Explore, Dream, Discover.
Mark Twain
CanadianNorth is offline
post #3 of 8 Old 10-25-2013
midlife crisis member
AllThumbs's Avatar
You can take it out but if you get holed your boat will sink. Since that foam is open cell it sometimes gets saturated with water. If that is the case you may as well remove it.
Most boats don't have foam. It was a selling feature for the Macs.
I sail.
AllThumbs is offline
post #4 of 8 Old 10-25-2013 Thread Starter
frscott's Avatar
Holed?? What is that? Sorry, limited lingo knowledge....
Scott
frscott is offline
post #5 of 8 Old 10-25-2013
Scott
I believe he means punching a serious hole in your boat, taking water fast. The styrofoam means you still have displacement. Without it, you will sink. Granted, your basically sunk either way ... Just not on the bottom perhaps
AllThumbs likes this.
___________________
High Hopes
Mark Twain
post #6 of 8 Old 10-25-2013
If its chopped up it will just float out of the holds, so its not going to keep you afloat.
Clean it out & if you want flotation in those spaces get some spray in flotation foam.
cruisingdream is offline
post #7 of 8 Old 10-25-2013
There is a MacGregor forum that is very, very active, and filled with knowledgeable people. Before you start moving the foam flotation around, I would talk to them. It's macgregorsailors.com. They helped us alot when we had a Mac.
momclarissa is offline
post #8 of 8 Old 10-26-2013
Hi Scott
I too have a mac 25, and yes the Styrofoam is for flotation. As was said just in case you get holed. In my boat I have a few good sized blocks under the cockpit area and under the V berth its almost full. If you do get holed at least you wont sink, the boat will float to some degree.
I also belong to the Macgregor.com board and they are a mine of info. Check them out. A great bunch of like minded sailors.
Anthony
anthony1 is offline
Compacting styrofoam Brent Swain SailNet FAQ 6 05-16-2012 10:26 AM
Insulation: Reflectix or Sheet Styrofoam coreywoodworking Cruising & Liveaboard Forum 12 01-15-2011 02:20 PM
White Styrofoam Blocks tager Sailboat Design and Construction 25 09-15-2010 09:23 PM
How much styrofoam bouyancy do I need? bottomfeeder Gear & Maintenance 2 02-02-2004 03:33 PM
