Newbie questions after first time taking out sailboat - Page 2 - SailNet Community
 6Likes
post #11 of 27 Old 10-27-2013 Thread Starter
Re: Newbie questions after first time taking out sailboat
Originally Posted by Delta-T View Post
More than likely the sails are tired. But I am sure they will not stop you from having fun and learning. Keep in mind you never run a flat sail...EVER! The sail needs curve, just like the wing of a plain, a sail is a plane wing on it's side. But works the same way with lift and pressure created by the shape of the sail, the curve. There are many good sail trimming instructional video's on U-tube about it. Use "sail trimming" for search.
Heh, I couldn't run a flat sail if I *wanted* to. Wind-sock is more like it
I'll check out youtube for sure. Thanks.
Bill B is offline
post #12 of 27 Old 10-27-2013
davidpm's Avatar
If you can why don't you take some good pictures and post them.
The most effective way to take pictures is the one two punch.
Take a picture from far enough away so we can get an idea of what we are looking at then another picture close in on the thing we want to see.
You can tie the boat off at the dock and on a light wind day get some good 360 pictures.
As much detail as you can.
If you do this the guys and gals on this forum can really let you know what is happening.
jimgo likes this.
davidpm is online now
post #13 of 27 Old 10-27-2013
Bill,
Do a search on "boom vang". This is the loop that you are describing but it usually involves a couple of fiddles and a cam cleat. Pretty handy. As far as a new sail, Ebay. There are also MANY sail lofts that specialize in used sails. I'd bet $100 would get you a nice one with lots of life left in it. I tie the gooseneck of my boom to the base of the mast, through a pad eye, before I tighten the main. This allows me to tension the luff properly. What might help you is buying a copy of Sailing for Dummies. No insult meant at all. I have a copy and studied for months before sailing. Great info written by sailing champions in regular guy language. A good resource.
As a trailer sailor, your needs are different that some others. This post has some great advice from knowledgable guys. Others I've seen are written by folks with big boats and very deep pockets. The things that will serve you (us) best is common sense and Yankee ingenuity couple with good sailing skills and COLREGS knowledge.
Don
DonScribner is offline
post #14 of 27 Old 10-27-2013 Thread Starter
I'll see what I can do. Unfortunately it will be another week or two before I'll be able to go back out.
davidpm likes this.
Bill B is offline
post #15 of 27 Old 10-27-2013 Thread Starter
Not a boom vang as far as I can tell from pictures. What I have is more like the "cleat for line to hold down boom" setup in the picture below (not my boat).
I hadn't thought about used. I'll check it out.
That's basically what's happening for me by virtue of the design. I hook the loop over the nub to stop the boom from riding up, then hoist until the luff is tight.
I have a copy and read through it once a while back. I reckon now that I actually have a boat, I should give it another read.
That's one thing I really like about sailnet - lots of nice folks who are willing to lend advice and experience, especially to a beginner like me.
Bill B is offline
post #16 of 27 Old 10-27-2013
davidpm's Avatar
If you let it ride up then use a line from the boom to the clean to pull it down you may be able to get the luff tighter.
The buggered shive at the top of the mast may make the above trick a good work around assuming that the luff needs to be tighter.
jimgo likes this.
post #17 of 27 Old 10-28-2013
Bill, If you have a good local sail maker this is what you should do to find out about the sail. If after you have all the line tight (halyard, out-haul, boom down haul etc.) you still have the slop in the sail put it up and draw it as tight as you can then have a set of pictures taken that show the sail under power. This will give the sail-maker a god view of what you sail is doing while on the water and he can better adjust your sail to fit what is needed. This is often much better then just dropping the sail off as it will give them some real world data on your boat.
Hope that helps,
Gary
gedaggett is offline
post #18 of 27 Old 10-28-2013
Drain plugs love to leak. Try some Vasoline around the plug next time. If it is the type with a proper O ring, what state is it in?
Next time, determine whether the water is salt or fresh. It could easily be some rainwater that collected somewhere, and moved while under sail.
Another trick you can try to find a leak is : fill the boat with water when it's on the trailer. Not too much though, it is heavy stuff and you don't want to cause structural damage to the boat or trailer by adding a ton of water.
MarkSF is offline
post #19 of 27 Old 10-28-2013 Thread Starter
I'll give it a try, thanks.
Bill B is offline
post #20 of 27 Old 10-28-2013 Thread Starter
It seems that the closest sailmaker is an hour or so away, and the ones with any kind of web presence are 2 hours or more. So I think pictures and an email assessment will be in order before I drop anything off to anyone.
Bill B is offline
Newbie looking at buying a sailboat with questions. BillA98272 Gear & Maintenance 10 02-16-2013 09:27 PM
Questions from a newbie. tausap Learning to Sail 29 06-25-2008 11:04 PM
Mickelson reverts to risk-taking form at worst possible time (USA Today) NewsReader News Feeds 0 06-19-2006 12:15 AM
Taking his time to send a boat back to the bay - Asbury Park Press NewsReader News Feeds 0 05-09-2006 07:16 AM
Newbie questions guyschwartz Boat Review and Purchase Forum 4 01-21-2004 05:44 PM
