Any one know a thing or two about booms - Page 3 - SailNet Community
 2Likes
post #21 of 33 Old 03-16-2014
blt2ski's Avatar
Re: Any one know a thing or two about booms
You're getting it. IE easier to slide something across ice vs concrete. Water frozen at 32F is virtually free of all friction, rubbing etc. Colder ice has more friction.
So in the case of single vs double line reefing, which ever setup has les line rubbing on something that will not turn, ala in grommet vs a sheave, this is harder to pull and get line to go thru. After awhile, you can not pull the line easy, and you need more purchase or a winch.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #22 of 33 Old 03-16-2014 Thread Starter
fllliging crazy.
abrahamx is offline
post #23 of 33 Old 04-13-2014 Thread Starter
So I cut off the chaffed end of my outhaul, along with the stopper knot and taped on some extra line to pull it through. It would not go, something was stopping it . So I untaped the line and went to the other side to try and pull it out the other way. When I looked up the line was gone into the boom. Doh! So I figured I had to pull off the fore end of the boom. two bolts out one broke and one stripped. Now I'm off to get a bolt getter outer kit and some taps for new holes. I somehow knew I could not just pull a new line through and be done with it.
abrahamx is offline
post #24 of 33 Old 04-13-2014 Thread Starter
Now I'm left with a stainless screw that I can not drill into to get out.
abrahamx is offline
post #25 of 33 Old 04-13-2014 Thread Starter
No wonder it would not pull through. I have two blocks about two feet apart with the bitter end running through them. then a cable runs the length of the boom connected to the end or the aft block. Fun stuff.
abrahamx is offline
post #26 of 33 Old 04-13-2014 Thread Starter
do I need a fitting or should I just tie a bowline.
abrahamx is offline
post #27 of 33 Old 04-13-2014
GaryM is likely correct. You probably have a multipart in you boom. This should give you some ideas: Harken I suspect that you'll need to pull the front cap off your boom to get out the old out. While you're at it inspect the block(s) to see that they are working well.
Hudsonian is offline
post #28 of 33 Old 04-14-2014 Thread Starter
already did that but its cool. I dont expect you to read the whole post before replying. Maybe I will start a new thread.
abrahamx is offline
post #29 of 33 Old 04-14-2014
jsaronson's Avatar
Be sure that you can access both ends of the line. On my boat, there is a 4:1 system with the end of the line attached to a becket inside the boom. The wire is attached to the aft block. Replacing the line would be a PIA!
jsaronson is offline
post #30 of 33 Old 04-15-2014 Thread Starter
it is a pia. I stabbed the pad under my thumb with a slotted screw driver bit on the end of my impact wrench trying to get the aft sheve off. I lost the line inside the boom then took off the fore end of the boom only to find what you are talking about. Block attached to end of boom and two blocks with wire attached to that running the length of the boom. Ofcourse my leader line broke off so I will now have to fish the line through if I ever get this sheve out of there. I have a couple inch square to fish the line through. My thumb is seriously messed up so it will be a week or more before I go back into it. I work with the tools for almost twenty years now and end up getting hurt at home. go figure.
abrahamx is offline
Horizontal booms royt Gear & Maintenance 4 04-19-2007 01:51 AM
Masts and booms CHEAP trecksail Gear & Maintenance 0 02-06-2005 09:15 PM
Deadly Serious about Booms John Rousmaniere Seamanship Articles 0 10-12-2004 08:00 PM
Need wood mast and 2 booms bill4991 Gear & Maintenance 2 06-05-2002 07:20 PM
Preventers on Wishbone Booms Mark Matthews Gear and Maintenance Articles 0 05-15-2002 08:00 PM
