Maintenance while in the boatyard. - Page 2 - SailNet Community
post #11 of 13 Old 10-30-2013
Delta-T's Avatar
Re: Maintenance while in the boatyard.
What kind of shaft seal do you have? One that takes packing or a drip-less PSS seal?
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #12 of 13 Old 10-31-2013 Thread Starter
Letrappes's Avatar
I have a normal seal that uses regular packing. I check on it from time to time. It drips like I'm told it should.
Letrappes is offline
post #13 of 13 Old 10-31-2013
Delta-T's Avatar
We had this thread going Stuffing box maintenance - interval and Delezynski suggested this...
"Back around 1998 or so, I repacked my stuffing box with moldable packing...
Dripless Packing Kit
I used 1/2 of the stuff for my 1 inch shaft. So far, I have not had to add any more. And by the way, my shaft does NOT have ANY DRIPPING. NO drip at any speed 0 to full RPM! AND, after running at high RPM for over 1/2 hour I can still reach down and hold my stuffing box with my bare hand.... no heat build up. I have also removed the shaft a couple of times for other maintenance and do not have any wear on it."
Eric
Delta-T
Delta-T is offline
Boatyard fire administrator General Discussion (sailing related) 0 12-21-2012 10:57 AM
Jacks boatyard. larrytwo Pacific Northwest & Alaska 3 10-04-2012 04:03 PM
DIY Boatyard in SC cd33nepenthe Gear & Maintenance 5 10-12-2009 05:42 PM
Boatyard Discussion Cheetie Gear & Maintenance 59 03-19-2009 09:31 AM
boatyard - connecticut rperret General Discussion (sailing related) 5 06-27-2003 07:29 PM
