Best way to remove barrier coat - Page 3 - SailNet Community
post #21 of 26 Old 06-17-2010
RichH's Avatar
Jeff -
Im a Physical Chemist, among other things. Ive observed over the years that the manufacturers recommended thickness of applied barrier coats has greatly increased over the past 20-25 years. Vapor permeability is dependent on 'thickness' of the epoxy barrier and those barriers applied 'in the earlier years' of relatively 'thin' recommendations have or are beginning to fail; the 'rate' of vapor permeation dependent on the average temperature of the ambient water. Once the water vapor 'can' penetrate there are 'many' causes for the vapor to 'stay behind' the barrier - chemical, mechanical, etc. but the principal mechanism seems to be 'discontinuous' lay-up where there are bonding discontinuities due to 'curing' between the laminate layers ... the action of simple hydrolysis of the internal structure; hydrolysis being equivalent of 'rusting' of (vapor porous) polymers.
THICK barrier coats better retard the vapor permeation; thus, better protecting vs. the inevitable 'hydrolysis'. In industry, FRG tanks that are laid-up in a single continuous process have much better resistance to hydrolysis damage and therefore last longer and with minimum 'blistering', etc.
RichH is offline
post #22 of 26 Old 06-17-2010
48' wood S&S yawl
cormeum's Avatar
Originally Posted by RichH View Post
Jeff -
For my purposes then, thin is better- I need some permeability as the planks will still need to take up.
I may have to deal with a lot of things, but fortunately, blistering is not one of them.
cormeum is offline
post #23 of 26 Old 06-17-2010
On the hard
CharlieCobra's Avatar
I can't see the need for a barrier coat on a wood boat. Anything else, yes. Wood? No...
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #24 of 26 Old 06-17-2010
48' wood S&S yawl
cormeum's Avatar
Talk to Bob Derecktor. he smeared it the first time so he must have had some ideas as to why. I can see that it would moderate the rate of transpiration so it's not necessarily a bad thing- why did they C-flex Oh Joy?
cormeum is offline
post #25 of 26 Old 06-17-2010
On the hard
Oh Joy suffered from electrolysis of fasteners only 18 months after being refastened due to a very hot marina. The owners at that time decided to refasten one last time and chose C-Flex over other sheathing methods to protect her from both marine borers and having to refasten again, with all of the issues that would entail. Unfortunately, going with canvas over ply in the traditional fashion for the deck, subsequent substandard maintenance, repairs and after they sold her, a total lack of maintenance, caused her current woes from topside fresh water leaks.
Bellingham, WA.
post #26 of 26 Old 06-17-2010
48' wood S&S yawl
cormeum's Avatar
Nuts.
cormeum is offline
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Barrier Coat existentialsailor Gear & Maintenance 2 12-19-2004 03:56 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
bottom paint barrier coat rbh1515 Gear & Maintenance 2 02-25-2001 03:52 PM
