Hard dinghy rubrail ideas? - SailNet Community
 3Likes
post #1 of 14 Old 10-31-2013 Thread Starter
I'm just finishing my Chameleon nesting dinghy and I am thinking about what I can use for a rubrail so it doesn't scratch my boat when I come alongside. I don't have a Westmarine here, so it has to be something I can find in a hardware or building supply store. Any ideas?? I thought about using soft hose tubing split to go around the gunwall or even lashing a pool "spaghetti" to the side, but neither will look very elegant... I need help!
Vindö 50
copacabana is offline
post #2 of 14 Old 10-31-2013
TomMaine's Avatar
Re: Hard dinghy rubrail ideas?
No, not a non marine item that works well. I've seen attempts(made a few myself) to find a cheap working rub rail.
The old standby canvas foam rub rail which is expensive up front (4-5.00/foot), I think is a good buy. I get 8 to 10 seasons out of it and I store the dinghy outside all winter in Maine. If you take care of it(store inside), you should get at least a decade out of it, maybe longer. It'll protect your boats topside and decks.
The best thing is, it works like no other rub rail. It's soft, well cushioned and best of all, for wooden dinghys like your Chameleon, it's easy to apply with screws and washers or boat nails(which I use). After all the work you've done, your project deserves it!
This is the second rub rail on a 20 year old Nutshell I built when my daughter was 2. Here she is sailing it this past season. You can order it from several suppliers.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
post #3 of 14 Old 10-31-2013
Group9's Avatar
I tried, and failed, as well, to come up with something as good as an old fashioned Taylormade, or other brand, canvas rubrail, for my Boston Whaler 11' dinghy.
I've used old firehose on docks, before, but I wanted something a little nicer looking on my dingy. I even considered using loading dock bumpers, something I had seen used on a marina holding tank pumping boat, but it doesn't save you any money.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #4 of 14 Old 10-31-2013
nodders's Avatar
I struggled with this question this season. I built a hard shell dinghy but due to time delays really didn't have time to address the issue before leaving on a 3 week cruise. As a temporary measure, I attached foam pipe insulation which started to fall apart after one day and wouldn't protect the corners of the dinghy which, of course, was the part that kept banging into my boat!
Finally, a few days into our cruise, I pulled out an old dock line and screwed it into the gunwale all around the boat. The line was soft enough that the screw heads went into the line far enough that they wouldn't scratch but the line was firm enough to hold the screw! Low and behold, it worked amazingly well. I will be sticking with that method. Looks rather nautical as well!
I am not really from Toronto
nodders is offline
post #5 of 14 Old 10-31-2013 Thread Starter
Tom, I like the look of that rubrail. Thanks for the idea and the photo. What kind of application exactly is the "canvass foam" manufactured for? Where would I begin looking for such a product? I fear my shopping here will be somewhat limited.
Group9, thank you as well for the suggestion.
Vindö 50
post #6 of 14 Old 10-31-2013
Old as Dirt!
svHyLyte's Avatar
Years ago we had a little El Torro that we used as a dinghy for our, then, Rhodes Reliant. I made a very nice rub rail for the boat out of discarded fire hose. I was able to buy a 25 foot length of 4" diameter fire hose from a local salvage shop that was roughly 6" wide when laid flat. We bought a length of 1/4" thick neoprene foam from a local wet-suit maker and cut it into 5" wide strips, sewed the ends together, and pulled it through the hose. We then used a punch and set snap buttons along both edges every 6-8" with matching buttons screwed and glued to the dinghy rails. It actually worked very nicely for many years. If you cannot find discarded fire hose, one could do the same thing with Sunbrella fabric and neoprene.
FWIW...
copacabana likes this.
svHyLyte is offline
post #7 of 14 Old 10-31-2013
no longer reading SailNet
Alex W's Avatar
I just use dinghy sized fenders. Polyform makes a nice one.
Alex W is offline
post #8 of 14 Old 10-31-2013 Thread Starter
Nodders, that just might be the solution for me. thanks.
Vindö 50
post #9 of 14 Old 10-31-2013
Old enough to know better
I have seen fairly large three strand rope used to very attractive effect, but I don't know if they just screw through it or how it is attached. Seems the least expensive and likely available.
miatapaul is online now
post #10 of 14 Old 10-31-2013
nodders's Avatar
I wondered the same. thought of using epoxy, but then removing it would be problamatic. The screws work really well and easy to remove should I need to replace it or remove for whatever reason.
Pictures of my futile attempt with foam pipe insulation can be seen on my blog linked to below....
nodders is offline
Ideas on which dinghy/small boat to buy? nygabe General Discussion (sailing related) 7 08-24-2013 12:47 AM
Jib furler is hard to furl since putting up new sail...ideas? NewportNewbie Gear & Maintenance 31 01-04-2013 01:43 PM
looking for dinghy/tender ideas bratzcpa Gear & Maintenance 15 12-03-2012 10:57 AM
Adhesive recommendation needed, dinghy rubrail josrulz Gear & Maintenance 2 10-13-2010 09:04 AM
Towing hard dinghy EClaire Gear & Maintenance 3 04-24-2003 08:47 PM
