Like Jeff H, I just did this, and I used the Primecoat like was suggested, I went with black on the mast, and used Interlux Perfection. The Perfection looks great, but like any painting requires great amount of cleanliness in process and honestly my experience is it requires you to be right at the proper temperature.
Where I disagree with Jeff, is Perfection suffers from being easily dinged as well on the mast, and while the primer is holding up great, the perfection already has multiple dings through it. I also had a VERY dirty environment to paint in, and I was thoroughly NOT happy with my results, which I totally attribute to my location of work, NOT the product. That being said, I think I'd have been happier leaving the mast just primed (it is a silver primer, and the mast would look bare).
Here are some pictures before, during, after, and in use...
Mast being sanded down to bare metal... Note mast color was flat white (probably originally gloss white)
Mast being primed, note primer is Interlux Primecote, silver in color.
Boom getting painted (note the environment? Yes that's hay, so totally my fault, and also note, it was about 45 degrees in the barn) I later sanded everything down and did more coats with it about 50-60 degrees in there, but it was still pretty dusty in that environment.
I can't find a close-up of the mast/boom, but it's probably better I didn't. There are places that shackles have smacked the mast, and removed the black down to the primer. The coating is softer than it should be (in my opinion)...
By the way, like someone else mentioned, I DIDN'T prime my spinnaker pole, just sanded it down and painted it with Perfection.... big sheets of paint are already peeling off! YOU MUST PRIME FIRST!
I like perfection but it's WAY to tricky for a Harry Homeowner like me to get right. I'm notoriously impatient with painting, and it requires proper timing, and technique to do. I did my prior whole boat hull topsides with Brightsides, and found it to be more acceptable to paint with. Again I am hugely lazy and impatient.
By the way, I TOO thought that sanding down to bare metal, and leaving it bare would be a good alternative, except, within days of sanding the mast, the aluminum starts to oxidize, and produces a light grey/black oxidation. I cannot imagine how quickly it'd turn nice white sails into dull/gray mess, and infinitely worse if we are talking about the deck. Perhaps the oxidation would provide it's own layer of protection I dunno, I just know that I wouldn't want my nice white sails any dirtier than they already are.
For the record, I think the proper primer USED to be a chromate primer... it's still available in places but is less easily available, and looks to be getting phased out.
I think if I had used pretty much ANY paint over the primer I applied, it'd have a similar level of success. picking gloss black, was probably NOT one of my better decisions. Flat black, or better yet, flat white probably would have been the wiser choice. I might redo the mast this coming winter, but I so DREAD the work involved I might just deal with it ugly.
Last note, I avoided painting the hull on my boat this winter for similar reasons to above. The location I have to work (and season of cold), and I can honestly say I didn't want to deal with it. I attempted to fix some gelcoat issues (coloring) on the port side of my boat, and was only marginally successful, I did that to avoid having to paint. After messing around with gelcoat a while I'd say painting is a VERY VIABLE alternative to dealing with it.
I'm not just blowing smoke either, this was my last boat (which was awlgripped 20 years prior and the paint was falling off), so painting was really my only option... And YES it was painted in the same location as the mast.
Before
After
