To do it myself or not ? - SailNet Community
 4Likes
  • 2 Post By asdf38
  • 2 Post By denverd0n
post #1 of 9 Old 11-01-2013 Thread Starter
Hey guys,
I need to replace a front engine mount and the stuffing gland (rubber tube behind the box around the shaft) I almost broke a wrist replacing the o-rings that hold the gland in place last spring ad noticed the rubber felt very thin.
I will need to remove the rudder and all the associated gear to get the shaft out, as well as lift the engine up to get the mount replaced....
I am wondering would it be folly to attempt this myself, or should I book an appt. at the local yard. If so, any idea what it would cost for such repairs ?
Thanks for any encouragement, sobering thoughts, or laughs !
M.
GaiaOrion is offline
post #2 of 9 Old 11-01-2013
Delta-T's Avatar
Re: To do it myself or not ?
It all comes down to time and money. And or your abilities and desire. I like doing my own work. But if I had money, others would be doing the work. So I will assume from your question that you are able and do desire to do it yourself. If the engine only needs to be lifted and not removed, I'm sure you could rig it.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
The Following User Says Thank You to Delta-T For This Useful Post:
GaiaOrion (11-01-2013)
post #3 of 9 Old 11-01-2013
asdf38's Avatar
You didn't mention the boat or engine, but I'll guess anyway for fun - assuming its a normal 25-40' boat I think you're in the $2k territory within +/- 300%.
That's what I'd expect for my boat and I'd probably go with a pro given my limited experience in the area of engines etc.
jimgo and Delta-T like this.
asdf38 is offline
The Following User Says Thank You to asdf38 For This Useful Post:
post #4 of 9 Old 11-01-2013
Learning the HARD way...
eherlihy's Avatar
What kind of boat?
I did all of this work myself two years ago. Specifically I;
  • dropped the rudder
  • removed the prop
  • removed the shaft
  • removed the coupling
  • removed the cutlass bearing
  • removed the shaft log
  • replaced the motor mounts
  • replaced the log with a PSS Shaft Seal
  • replaced the cutlass bearing
  • replaced the shaft
  • replaced the coupling
  • had the prop polished & balanced
  • re-installed the prop
  • re-installed the rudder
  • realigned the engine
You can read about that here: Contemplating a drive line overhaul
Take your time, and do it well. If nothing else, you will know who to blame if anything breaks.
To replace the motor mount, either take a trip to a local junk yard and look for a Honda Civic, or go to harbor freight, and get a small scissors jack. The Civic uses a very small (like 2" vertical) jack that should fit under the motor. The one that I bought cost me $10.
Good luck, and post us here to let us know how you made out.
eherlihy is online now
The Following User Says Thank You to eherlihy For This Useful Post:
post #5 of 9 Old 11-01-2013
Delta-T's Avatar
I installed the PSS seal too and manufacture recommended, and sells a kit, replacing the rubber boot every 6 years.
Eric
Delta-T
Delta-T is offline
post #6 of 9 Old 11-01-2013
denverd0n's Avatar
This is one of those kinds of questions where I figure, if you have to ask, then the answer should be "no." That is, if it were something that you should be tackling on your own, you'd know it; you wouldn't need to ask.
Good luck, whatever you decide to do.
xymotic and Delta-T like this.
denverd0n is offline
The Following User Says Thank You to denverd0n For This Useful Post:
post #7 of 9 Old 11-02-2013
JimsCAL's Avatar
The biggest piece of that job is dropping the rudder. If you can deal with that, I would say do it yourself. I've done that several times on boats up to 30 foot with a tiller. Bigger job on larger boats with a wheel.
JimsCAL is offline
The Following User Says Thank You to JimsCAL For This Useful Post:
GaiaOrion (11-02-2013)
post #8 of 9 Old 11-02-2013
Remember you're a womble
PaulinVictoria's Avatar
It's often not the complexity of the job, but the lack of the proper tools that prevents DIY, I'd give it a go and see what happens. Worst case you end up paying someone to finish the job and as long as you don't just go cutting and hammering everything in sight, you shouldn't make the job any harder than it would have been.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #9 of 9 Old 11-02-2013
Omatako's Avatar
Why do you have to get the shaft out?
Arthur C. Clarke
Omatako is offline
