Draining Water from Rudder - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 11-03-2013
Re: Draining Water from Rudder
Originally Posted by swallace11 View Post
.....I guess that this relys on the fact that corrosion underwater in absense of air is limited.....
Corrosion of stainless steel is caused by this, as stainless relies on a microscopically thin layer of oxidation to prevent the steel from rusting. This layer does not form or replenish in the absence of oxygen, therefore, the iron is at risk. Read up on crevice corrosion.
Jeanneau 54DS
Minnewaska is offline
post #12 of 15 Old 11-03-2013
One of None
deniseO30's Avatar
E and I have huge rudders.
It behooves us to take care of them LOL
My last project!
deniseO30 is offline
post #13 of 15 Old 11-03-2013
The rudder armature has failed on two of the nine Tartan 30's at the Club where I'm a member. As I recall, both required significant repairs to the skeg shoe while the rudder was off.
Hudsonian is offline
post #14 of 15 Old 11-03-2013
If rudders eventually fill with water, why not design a rudder that can be submerged and inspected. I'm thinking a few basic structural components such as ribs and spars(rudderpost) with a covering of plastic, riveted on. The shape is the same and with holes on the top and bottom it could fill with water, then drain when hauled out.
Anyone see anything out there like that? With a roll of plastic, rivets and some spare ribs you could even keep a spare rudder stored on board unassembled.
Wing design
Caridea is offline
post #15 of 15 Old 11-04-2013
mitiempo's Avatar
Rudders that do not suffer from water absorption have been designed and built. The problem is that the stainless rudder post and armature inside and the fiberglass covering it have different expansion rates, making it impossible to seal the fiberglass to the rudder post for the long term. The post and rudder have to be made of the same material. Carbon fiber rudder posts are used on some boats and don't have this problem. Expensive though.
Brian
mitiempo is offline
Water comming up through the rudder post egle01 Gear & Maintenance 9 05-09-2015 10:11 PM
Rudder draining, repair, etc. kwaltersmi Gear & Maintenance 8 09-28-2012 11:00 PM
Water in rudder Barquito Gear & Maintenance 18 10-18-2010 03:01 PM
Water in the rudder - now what? pmoyer Gear & Maintenance 11 12-30-2007 04:49 PM
Draining water tanks teshannon Gear & Maintenance 39 06-24-2007 10:45 AM
