No baby stays, should I consider adding them? - SailNet Community
post #1 of 4 Old 11-04-2013 Thread Starter
Catamarans are the best
Subaqua's Avatar
Location: North Dakota -the land of ice and snow and 650,000 other people
Looking around at all the boats he in the marina, the leopard 39/moorings 3900 is one of the few, or maybe the only one, that doesn't have a baby stay. Apparently not necessary, but if I'm going a bit more than near island chartering, is it something I need. At least, I'm sure, it's something to consider. What do I gain? Must be the mast is just so short and stout that it's not so necessary... After all, it did get here from S. Africa. Did I just answer my own question?
Subaqua is offline
post #2 of 4 Old 11-04-2013
Re: No baby stays, should I consider adding them?
Originally Posted by Subaqua View Post
... Did I just answer my own question?
Sounds like it. Baby stays are added to rigs if required to either minimize the tendency to 'pump' or as a way to induce mast bend in a breeze. Their presence is usually a PITA when tacking, as they are prime candidates to hang up the headsail during a tack.
I'd assume the designer(s) made the right calls and be thankful you don't have a babystay.. unless circumstances appear to dictate the need.
Faster is online now
post #3 of 4 Old 11-04-2013
SchockT's Avatar
Yeah, you don't need to second guess the rig designer. Baby stays are used to stabilize or adjust the mast on certain rig types. For example, my mast has no sweep to the spreaders so it would be more prone to pumping without the babystay. There are thousands of boats out there that do not need one.
Now if it looks like your boat used to have one, and someone removed it, THEN you might consider reinstalling it.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #4 of 4 Old 11-04-2013
djodenda's Avatar
Faster's forestay is really more a babystay than anything else...
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
Adding an adjustable backstay without adding a split backstay peterchech Gear & Maintenance 11 05-29-2012 05:33 PM
baby stays davemchine General Discussion (sailing related) 4 04-23-2012 05:22 PM
Adding tangs for running back stays downeast450 Gear & Maintenance 5 10-29-2009 07:19 AM
what stays, what goes? tybeefolk General Discussion (sailing related) 6 01-10-2004 03:34 PM
