Edel 665 halyard winch handle - SailNet Community
Advertise Here
Like Tree2Likes
Old 11-04-2013
mitchross is on a distinguished road
I have an Edel 665 built in 1980. I'm trying to identify the manufacturer of the winch used for the main and foresail halyards. They are not drum but cam clutch in design. on the front side of the handles are an "N" and "M" with a stylized sail boat in between the two letters. On the reverse is a US Patent NO. " 3770244". I'm hoping to replace or rebuild the handles which have a spring and nylon tube inserted at the attachment point. Any help would be appreciated.
  #2
Old 11-04-2013
Stumble is on a distinguished road
Re: Edel 665 halyard winch handle
Can you post pictures?
The original patent was filed by Robert McCloud in 1972.
A schematic of the system is located https://docs.google.com/viewer?url=p.../US3770244.pdf
I couldn't find any reference to the patent being assigned to anyone, and I don't know that branding. From the patent itself it looks like a pretty odd little winch however.
Greg Rubin
Attorney
  #3
Old 11-04-2013
Thanks, I had gotten the same info from PTO. The only difference between what is on my boat and the original patent diagram is that mine are mounted vertically on the the main mast with lines fed up from the internal halyard runs. I have pictures if that might help identify the manufacturer.
  #4
Old 11-04-2013
andrewalexander's Avatar
Irwin 25
andrewalexander is on a distinguished road
hmmmm...interesting - mine is a Lewmar 6 on the mast and 7's for the jib sheets and original to the boat - and a 1980 as well (Canadian built I believe) - this will be fun to watch what you find out.
Also, perhaps you may have a French built version.
  #5
Old 11-04-2013
Yes to pictures... curious now.
  #6
Old 11-07-2013
Here is a picture of the winch with the handle attached.
  #7
Old 11-07-2013
Mitch,
I have never seen anything like that... I couldn't even begin to guess where to get spare parts. Sorry.
Greg Rubin
Attorney
  #8
Old 11-07-2013
Looks more like some kind of 'super cam cleat' that needs extra leverage to release (hence the handle).. don't see that as being any kind of winch...
  #9
Old 11-08-2013
i_amcdn is on a distinguished road
Send a message via ICQ to i_amcdn Send a message via MSN to i_amcdn Send a message via Yahoo to i_amcdn
I have one of those on my Edel. Had no idea what is was used for and still don't get it. My lewmar is on the deck just beside the hatch, on the wrong side. I dropped the mast for first time since I bought it and in the spring I will run the main halyard out the correct side of the mast.
My boat is all wrapped up otherwise I would go get the handle an look at it more closely.
1981 Edel 665
Currently on the hard beside Toronto Harbour.
  #10
Old 11-08-2013
mitiempo's Avatar
Looks like a line jammer to me - not any kind of winch. Designed to protrude from the mast less than the conventional type. A boat that size doesn't require a halyard winch really.
Faster and Sabreman like this.
Brian
You may post attachments
You may edit your posts
Old winch handle replacement L124C Gear & Maintenance 28 09-04-2013 06:10 AM
Barient Winch Handle lamb@cshl.edu Gear & Maintenance 6 10-20-2011 05:51 PM
Looking for an old winch handle j1brady Gear & Maintenance 22 10-01-2010 08:37 PM
winch handle marthajewel Gear & Maintenance 7 02-25-2009 10:57 AM
Winch Handle Holder THOMASRHEUBLE Gear & Maintenance 11 10-21-2006 07:37 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
