My Manual Bilge Pump is Useless - Page 2 - SailNet Community
 2Likes
post #11 of 20 Old 11-04-2013
Coquina's Avatar
Re: My Manual Bilge Pump is Useless
I too had a cockpit sole bilge pump that didn't pump much at all and leaked water into the boat. I got a new one, installed it in the side of the cockpit instead of the floor, and epoxied the old hole shut. You DO want the manual pump - mine pumps WAY more than both electrics combined and way way more than a handheld type.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #12 of 20 Old 11-04-2013
manatee's Avatar
Perhaps refurbish the pump and bed it with this. Even if the pump shifts from the stress of use, the butyl should maintain a seal.
mitiempo likes this.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #13 of 20 Old 11-04-2013
asdf38's Avatar
I have an inspection plate (screw on type) in that area and it's quite useful. If it leaks it doesn't leak much. This year I went 2 months without enough water to prime my bilge pump. The particular location is important - I wouldn't want an inspection plate in a place where water can actually pool.
Originally Posted by eherlihy View Post
BTW - Where does one purchase Dow 795?
McMaster.com
asdf38 is offline
post #14 of 20 Old 11-04-2013
Remember you're a womble
PaulinVictoria's Avatar
Rebuild the manual pump, I've done this on two Whale pumps and in both cases I didn't actually have to replace any of the seals or the diaphragm. Both times there was corrosion in the pump body and when everything was cleaned up and reassembled the pumps were good as new.
Have you actually tried pumping out from the bilge overboard using your hand pump? You do have a hose that reaches right? If you are alone and pumping like crazy, the last thing you want to be doing is stopping pumping to go and empty the bucket overboard.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #15 of 20 Old 11-04-2013
TakeFive's Avatar
Originally Posted by PaulinVictoria View Post
...Have you actually tried pumping out from the bilge overboard using your hand pump? You do have a hose that reaches right? If you are alone and pumping like crazy, the last thing you want to be doing is stopping pumping to go and empty the bucket overboard.
Or you can pump into the galley sink or head sink.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #16 of 20 Old 11-05-2013
Yep, as long as you can make the hose stay in the sink, and you remember to open the seacock etc. Can't beat the simplicity of hanging a hose off the toerail, or better still going for it with a properly mounted manual bilge pump.
Orange Crush
1974 C&C27 MkII
post #17 of 20 Old 11-05-2013 Thread Starter
I hate it when everyone else is right!
FirstCandC is offline
post #18 of 20 Old 11-05-2013
Chastened
Ajax_MD's Avatar
This is what I was going to suggest. Install a bulkhead mounted pump, and seal up the old hole. I don't see why you couldn't install the access port.
1981 Tartan 33 #168
Ajax_MD is online now
post #19 of 20 Old 11-06-2013
Old enough to know better
Yes, you want a manual pump and one that you can use from the steering station. You don't want to have to go below to pump as a manual hand pump would require. that way you can keep watch while pumping, and if it flails to keep up you will be on deck. I looked at one boat that had the normal spot to put a pump handle in the cockpit and one in the head. I asked if it was a manual pump out for the holding tank, and he said no just another manual bilge pump. Guess he had two activities he did not want disturbed if he had to go to manual pump mode!
miatapaul is offline
post #20 of 20 Old 11-06-2013
I sail on a Ranger 29 that has 2 manual pumps in the cockpit. I would imagine if I have to use both it is just to stay afloat till the coasties get to me.
gedaggett is offline
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 09:59 AM
Which Manual Bilge Pump? Perithead Gear & Maintenance 12 01-25-2012 04:51 PM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 08:26 PM
manual bilge pump billdre O'Day 1 05-19-2010 09:39 PM
Manual Bilge Pump backcreeksailor Gear & Maintenance 13 04-18-2009 02:02 AM
