Saildrive Grinds into Gear - SailNet Community
post #1 of 4 Old 11-04-2013 Thread Starter
I just splashed my boat after 3 years on the hard.
I ran the engine on the hard using a hose and bucket directly to the water pump and everything was fine. Switching into forward/reverse went real smooth.
After 2 days in the water I started up the engine only to hear a loud grinding noise every time I switched into forward and reverse....wtf?
So I check my gear oil and I find a nice milky emulsion spewing over the fill cap of the saildrive. Break some more cash for a haul...f*ck!!
So it's obvious I have water in my saildrive and I have new seals and O-rings on order.
I'm curious though, is this enough to cause the loud grinding when put into gear? I wouldn't have thought this would be enough to cause this.
Should i be worried it's something else?
Freerider is offline
post #2 of 4 Old 11-04-2013
tommays's Avatar
Re: Saildrive Grinds into Gear
What kind of drive ?
I will assume which is never good you had the water in there a good long time ?
Or was the drive oil changed while it was hauled ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 4 Old 11-04-2013 Thread Starter
Yanmar SD 20
No the oil was changed and the old stuff looked good. I guess maybe the o-rings and seal may have dried up over the years.
post #4 of 4 Old 11-04-2013
overbored's Avatar
That much water in the gearbox will make it shift and sound like there is no oil at all
"GOLD RUSH" PRINDLE 16
overbored is online now
Gear confessional: what was the last piece of gear you bought merlin2375 Gear & Maintenance 60 07-05-2008 10:45 AM
You know what grinds my gears? eMKay Gear & Maintenance 15 05-12-2008 07:43 AM
Johnson Saildrive 15hp gears clacking when in fwd gear Lancer28 Gear & Maintenance 1 09-03-2007 10:10 AM
Bay Shore sailor grinds out America's Cup win - Newsday NewsReader News Feeds 0 07-05-2007 10:15 PM
Saildrive mikehoyt Gear & Maintenance 0 10-30-2002 12:03 PM
