Continuous Sheets - SailNet Community
 1Likes
post #1 of 12 Old 11-05-2013 Thread Starter
pdqaltair's Avatar
Continuous Sheets
I searched and all refferences were to continuous sheets wherein the center point is cow hitched to the genoa clew. I am reffering to contiuous sheets where the ends are attached to the clew and the starboard and port sheets are contiuous with each other, as is done on beach cats and dingies.
My genoa sheets were due for replacement today; the clew end had been destroyed by years of flogging (Kevlar core blown--of course, this was the wrong line choise) and the PO left nothing to trim off. Since the rope I had was long enough for both with a good bit left over (free line), I decide to rig it as continuous and see how that felt. I have always been annoyed when the lazy end is pulled over to the turning block, which is out of reach of the cockpit on my boat; I can go get it easily enough, but why? Of course, longer sheets would minimize this... but that is more line in the cockpit.
Yes, there is a bit more rope in the cockpit with a contiuous sheet--no, actually considerably less since the working sheet feed to the lazy sheet, but one strand does cross from one side to the other. Tacking seemed simpler, easier to find the rope to haul in on the other side when short handed; it's the same line you are releasing from the old working winch. Fewer tangles; one of the advantages of a continous line is there is no end to form a knot. Of course, anchoring the end of any line does that.
My traveler (long on a cat) was continuous stock from the maker. Works well and simplifies line managment.
So why not contiuous genoa sheets, which are universal on small boats? I can see separate lines for the chute (nice to coil them away as they are not used most days). Perhaps it is one of those things that works with some layouts and not others. In my case the sheets run behind the deep cockpit (center cockpit), which helps; it feels like a beach cat layout now. I can see if they had to run across the center it would be a drag.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #2 of 12 Old 11-05-2013
Re: Continuous Sheets
We've been using a continuous sheet as you describe for our A sail... it is a lot of line in the cockpit and I'm reconsidering it.
But we have used that system in the past on a 28 footer, it worked well enough. It is odd that more people don't use it, if only for the 'reachability'... I'd think it also minimizes the risk of a sheet tail going overboard and getting wrapped up in the prop...
Faster is online now
post #3 of 12 Old 11-05-2013
continuous sheets are great if your alone on the boat, that is what I'm going to do on mine next year, I tried it this year by tying both sheets together and it was a really nice setup to use and if you have a continuous sheet you can have it shorter, so less line in the cockpit
fred1diver is offline
post #4 of 12 Old 11-05-2013
I use a continuous sheet on my 36' giant beach cat, and it really does make life easier. As you suggest, how practical it is depends on the layout of the boat.
RobertKWFL is offline
post #5 of 12 Old 11-06-2013
One thing you need to consider before going with such a setup, is whether it will impair your ability to maintain proper sheet leads when using a whisker pole, or when broad reaching... Certainly wouldn't work on my boat...
My jib cars are inboard of my lifelines, so if I'm rigging for sailing DDW/wing on wing, I need to re-route the sheet underneath the lifelines via a snatch block clipped to the toerail... Same thing when broad reaching, and I want to open the slot by moving the lead outboard to the rail... Or, when deep reaching and the genoa starts getting blanketed by the main, and you might want to lead the sheet to the end of the boom to inhibit it from collapsing. On my boat, I couldn't do any of that with a continuous sheet - or at least it would be problematic to do so, and likely require a lot of extra sheet length, anyway...
Another downside I see, is that you're always stuck with some sheet in the cockpit... Many times, when I know I'm not going anywhere for a while either at dock or at anchor, I'll coil my sheets and stow them forward, clearing the cockpit and side decks a bit...
Faster likes this.
JonEisberg is offline
post #6 of 12 Old 11-06-2013
I don't discuss my member
zz4gta's Avatar
Only way to larkshead a continuous sheet is to splice in place Or have a lot of snatch blocks. Either way I'm not a huge fan. For travelers I love a continuous sheet.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #7 of 12 Old 11-06-2013
Yes, and am I missing something here?
If one actually did that, how would you ever remove the sail and sheets from the boat, without cutting it? Sure, you could use a shackle to attach the sheet to the clew, but you'd still be left with a continuous loop around the mast and shrouds, no?
post #8 of 12 Old 11-06-2013
Another possible downside is that during a tack the 'freed' end is not really free until you sheet the new side in, so there may be more drag or it may simply be slower unless enough extra length is provided..
post #9 of 12 Old 11-06-2013
One way to solve it would be to use Dyneema rope with cover for the sheet and make a naked eye splice in both ends.
These splices will be small enough to pass through blocks, attach the ends to the sail with soft shackles.
That way you could easily take it completely off when not in use.
knuterikt is online now
post #10 of 12 Old 11-06-2013
Of course, good idea, that would definitely work, why didn't I think of that?
But, still, not for me... :-)
continuous furler? adamsj23 General Discussion (sailing related) 10 12-02-2011 06:34 PM
Continuous Furler line overbored Gear & Maintenance 3 05-17-2011 05:44 PM
Continuous Hot Water Heater ArgleBargle Gear & Maintenance 6 10-21-2008 07:10 AM
Genoa/Jib Sheets - one continuous or two? chappyonice Gear & Maintenance 4 06-29-2007 12:25 PM
