Bilge Pump Blues - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 11-12-2013
radcat's Avatar
Re: Bilge Pump Blues
Anytime there is a change in component performance, it is helpful to look at what changed since it last functioned correctly. You said you were winterizing the systems. Did you take anything loose, break any seals?
Radcat
PS 37
Hull# 210
radcat is offline
post #12 of 15 Old 11-12-2013
outbound's Avatar
Brian- Thanks for the thought. Did pump for ~10 minutes as thought of that given the long run of the hoses. Would have thought even if nothing coming out would get some resistance at the handle but get nothing. So thought maybe a hose clamp or something got loose so couldn't develop suction and that's why no resistance at the handle. Looked and can see no source for leak.
They maybe "junk" and a scared man with a bucket maybe be the best bilge pump but the manual pump(s) would get that last little bit of water out of the bilge which the electric pumps don't. A bone dry bilge is a nice thing. Don't get why both worked in past and neither work now. Was told something about a one way valve in them which maybe fouled. Haven't taken the pumps apart yet but that maybe next step unless someone has further thoughts.
s/v Hippocampus
Outbound 46
outbound is offline
post #13 of 15 Old 11-12-2013
Best Looking MALE Mod
Cruisingdad's Avatar
Mine has a "check valve (really a one-way valve)" at the very end of the tube. It is a screw on, but I cannot imagine how that type of valve would fail. Have you tried putting some water in a small bucket and seeing if it pumps it out?
Brian
PS I would make sure mine worked too. But being a new boat, I would be on the telephone with Outbound!!
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #14 of 15 Old 11-12-2013
outbound's Avatar
Thanks Brian- The call went in and so far they been very good about support.
s/v Hippocampus
Outbound 46
outbound is offline
post #15 of 15 Old 11-12-2013
I have no doubt. Great boat. Nor as good as a Catalina 400, but still a great boat (snicker).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
1 GM 10 H2O pump blues Janus Diesel 11 11-21-2010 07:28 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Cooling pump blues sanuni Gear & Maintenance 4 01-30-2002 11:55 AM
