Pearson 26 Rudder Lost - know of any for sale? - SailNet Community
 1Likes
post #1 of 21 Old 11-11-2013 Thread Starter
Good evening everyone. Went for a sail on the Magothy yesterday on my Pearson 26 and the rudder sheared off at the hull line. I've had her for 2 years and in that time completed a week long cruise around the bay and, in early October, completed a Delmarva circumnavigation. Have also been out in 20+kts many times before with no issues. I suppose I was sailing on borrowed time.
Fortunately the incident happened right in front of a marina and I was able to sail enough to pull her into a slip with no other damage. I've looked at D&R, Foss Foam, and Mass Marine parts so far but wanted to put a call.
All that said, does anyone know of a p26 rudder with a stainless steel shaft for sale?
Thanks in advance!
kjones is offline
post #2 of 21 Old 11-11-2013
One of None
deniseO30's Avatar
Re: Pearson 26 Rudder Lost - know of any for sale?
Why don't you do some diving to find the old and rebuild it?
My last project!
deniseO30 is offline
post #3 of 21 Old 11-11-2013
mitiempo's Avatar
If you know where it separated diving could be a good idea. If you don't know exactly it could be a career though.
Check around for P26's being parted out.
I would re-post the question here Pearson - SailboatOwners.com
It is the Pearson Owners Group, part of SailboatOwners.com
At the very least it will probably lead to the measurements and then you can make one.
New rudders can be expensive. Foss Foam (at NewRudders.com) lists the P26 rudder as a standard stock item.
Brian
mitiempo is offline
post #4 of 21 Old 11-11-2013 Thread Starter
Thank you mitiempo. I'll certainly post there as well. I've though about making a new one as this year's winter project and plan to solicit some feedback/guidance on that front as well.
Diving for it unfortunately is probably a fools errand. Couldn't pin point where exactly is fell off and the chesapeake mud, I imagine, is slowly burying it. Would it be be possible to rebuild a rudder with a broken shaft? Would that just entail welding on a new section of tubing?
kjones is offline
post #5 of 21 Old 11-11-2013
I priced out rudders for my p26 last year. D&R and Foss both quote around $1600. Massmarineparts sometimes has salvaged rudders, and they quoted around half of new. The problem with used is that you need to make sure that the stock is stainless, not aluminum, which was stock on the earlier P26.
tsell is offline
post #6 of 21 Old 11-11-2013
mitiempo's Avatar
I would use a new shaft since yours is broken. Stainless preferred as the size is small on yours - guessing 1" maybe. A good welding shop can create the armature necessary and attach it to the new shaft. I don't think aluminum is a good choice.
Here is an interesdting article on rudder construction by Charlie Doane at Wavetrain FIBERGLASS BOATBUILDING: Rudder Construction
The easiest method would be plywood and epoxy layers faired at the edges and glassed totally afterwards.
Brian
mitiempo is offline
post #7 of 21 Old 11-12-2013
One of None
deniseO30's Avatar
mitiempo likes this.
My last project!
post #8 of 21 Old 11-12-2013
Not the cheapest thing around but here you go.
DR Marine Product Detail
You could also try these guys.
NewRudders.com Standard Rudders
gedaggett is offline
post #9 of 21 Old 01-15-2014
Don't know if you have solved this yet or not but I happen to have a spare rudder that I could part with for a price substancially less than that offered by D&R. Reply here and we can discuss details.
ratherbesailingri is offline
post #10 of 21 Old 01-16-2014
timtim's Avatar
is that P26 rudder this available? I have a friend also that needs one.
timtim is offline
Tags
pearson 26 , rudder
Lost my rudder! TheMadchef General Discussion (sailing related) 16 08-31-2013 02:09 PM
Rudder lost at sea and rescue CalebD General Discussion (sailing related) 81 03-25-2013 06:04 PM
Lost Rudder maineman Gear & Maintenance 17 10-11-2009 07:18 PM
lost rudder clifacs General Discussion (sailing related) 2 06-22-2009 08:18 AM
Lost Rudder at Sea MarkAW Gear & Maintenance 0 08-22-2001 09:54 AM
