I bought my first boat.. now i have a million question - Page 3 - SailNet Community
 7Likes
post #21 of 28 Old 11-14-2013
I, too have a Cat 27 and although mine wasn't surveyed have did a visual survey of the chain plates and they look to be in good condition and the wood solid. Having read this I will look further into their condition but as stated with an older boat prioritizing the maintenance is a key asset! I put better sails on mine including a new mainsail. I have leaking keel bolts and have epoxied the smile and am having the nuts ground and tightened! Couldn't do it in the water as with my previous C& C as the nuts and bolts aren't stainless and the previous owner left a good sized divot where he hit a rock so had to do a visual first. I received a generous settlement through insurance as an errant boater teed off on my stern pulpit in the slip so I can upgrade and repair that soon.too. I was lucky enough to inherit a newer Furlex roller furler but I singlehand the boat with my dachshunds so that and an auto tiller are a must. As stated every sailor's needs and every sailboat is different so hope you're able to have your new boat ready by next spring and a good teacher would help learning the ropes!
ahab211 is offline
post #22 of 28 Old 11-14-2013
Re: I bought my first boat.. now i have a million question
ahab211 My Cat 27 was in salt water all of its life. That probably added to the condition. Plus, I bought it on a bank repo sale, so who knows if ANYONE had done much maintenance. rich
richg99 is offline
post #23 of 28 Old 11-14-2013
At epoxyworks.com find and read the article on "Replacing damaged bulkheads". It'll start you in the right direction on the chain plates
Hudsonian is offline
post #24 of 28 Old 11-15-2013
mitiempo's Avatar
Sorry for the error.
I missed a digit - corrected now. Rare for a chainplate to fail that quickly (12 years) from corrosion, may have been flawed from new.
I replaced my main chainplates after 36 years but after pulling the originals they still looked good with no visible corrosion. New ones are longer with an additional bolt through the bulkhead and 316 as I bought the raw stock and had my welder finish them for me.
Delta-T likes this.
Brian
mitiempo is offline
post #25 of 28 Old 11-15-2013
Delta-T's Avatar
So how come something can last30/40 years with no issues and you replace it with new and the quality sucks and you now have to replace every 10 to 15 years?
Sorry for the OT
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #26 of 28 Old 11-15-2013
mitiempo's Avatar
I had to pull the plates to check them. Replaced with 316 as I doubt the originals were 316 - most likely 304. 316 is slightly weaker than 304 and a longer 3 bolt plate costs virtually no more than the original 2 bolt plate. Added risers on deck so there will never be a puddle of water around the base so the plate had to rise higher above the deck, therefore had to be longer even if I kept to the 2 bolt
design.
I think the new chainplates will last at least as long as the originals, but I won't.
Brian
mitiempo is offline
post #27 of 28 Old 11-15-2013
Pessimist!
Faster is online now
post #28 of 28 Old 11-15-2013
mitiempo's Avatar
If they do last as long as the originals I will be 97. On the other hand my mother is a fairly healthy 93.
Brian
mitiempo is offline
CBMM boat auction - I bought the cheapest boat there - what is it? sealover General Discussion (sailing related) 10 09-06-2012 09:59 PM
Bought my first boat OmahaSailer Boat Review and Purchase Forum 5 06-24-2012 12:20 AM
$1 million boat sinks; family safe - Miami Herald NewsReader News Feeds 0 06-01-2007 05:16 AM
Bought My Boat wannasail Boat Review and Purchase Forum 1 05-01-2002 07:10 PM
Bought a boat mojizm Boat Review and Purchase Forum 2 01-08-2002 03:38 PM
