Stove options - Page 2 - SailNet Community
 15Likes
post #11 of 46 Old 11-13-2013
mitiempo's Avatar
Re: Stove options
You mean CNG?? Compressed... rather than Liquified...
Like propane it is liquid I believe in the tank, but a gas when released. It is the only type of stove I have not used.
Duchess
First question - where will you be going? Cng is only available in some parts of North America, not in the rest of the world. Alcohol is rare in most parts of the world and very expensive if found. I have heard it said that in the Caribbean it is less expensive to use overproof rum! Alcohol is needed to prime a kerosene stove unless you use a propane torch which also works. As posted the kero burners are not produced anymore, the last ones we received were made in Portugal and very poor quality as well.
I have owned and cooked on kerosene stoves (Primus) in the 60's and early 70's, alcohol (the worst or the lot) and actually gasoline - Coleman stove used outside only in the 60's on my first small boat. For the last 25 years I have used propane and wouldn't go back to another fuel even if I was paid to.
The only reason Origo and other alcohol stoves are popular is because many are scared of propane. On a cooking basis only comparison propane would be the choice of the majority as it is with any professional cook, electric being not as good and not a choice on a small boat.
Propane is safe if used properly. All burners now have shut-offs if the flame goes out. It is one of the cleanest fuels. It doesn't smell in use nor make people nauseous as alcohol can. It is available worldwide - outside North America it is the major cooking fuel in virtually every country.
The tank can be rail mounted as many have done, which eliminates the need for a sealed locker. Propane sniffers can be purchased at a reasonable price.
I would recommend an Eno 2 burner gimbaled stove like the one shown at the bottom of the catalog pic below. It comes with pot holders and is easy to keep clean. Eno is Force 10 and they are available at any good marine store.
Brian
mitiempo is offline
post #12 of 46 Old 11-13-2013
Wandering Aimlessly
PBzeer's Avatar
Re: Stove options
Like choosing a boat, choosing a stove should be based on how you'll actually use it. If you're basically just heating stuff up, cooking some eggs and such, the Origo type is fine, and you can get fuel at any hardware/big box store. If you're more into "cooking", than I'd go with propane.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #13 of 46 Old 11-13-2013
mitiempo's Avatar
Re: Stove options
Agreed. I believe the Duchess wants to travel far.
Brian
mitiempo is offline
post #14 of 46 Old 11-13-2013 Thread Starter
Re: Stove options
Originally Posted by SVTatia View Post
Hi duchess
You have to do your homework on how the different stove fuels work and how efficient they are, then decide which one to have. I donít remember seeing a stove that burns gasoline or anyone insane enough to want it.
Alcohol is ok for weekends but it does not have the BTUs for everyday cooking and is only available in the US and Canada. You can use other fuels on the stove but you take the chance. Kerosene in my opinion is the best, having used it daily for many years with no problems whatsoever, no soot, no flare ups no dirty pots, no smell. It does not have the same BTUs as propane, and you need to prime, but you donít need the extra monitoring necessary for a gas stove. The insurance companies like it too. However, the market dictated that propane is more convenient, because you just light it and cook, so the special kerosene burners are no longer available, at least I cannot find a source for the burners and parts anymore.
Gas has its drawbacks, but as stated above, if you take all the precautions, you should be fine.
Choose a stove that is easy to find parts and a fuel that does the job, this will be your home and you need to use the stove 3, 4 times everyday Ė so avoid having to start all over again when you get tired of eating cold or uncooked food.
so if kerosene is best which i have also read on atom voyages website, what is a good kerosene stove and where do i get one. last summer and the summer before i survived on uncooked canned, you do what you have o but id like to be able to eat things other than canned beans, soup and corn.
duchess of montrose is offline
post #15 of 46 Old 11-13-2013 Thread Starter
Re: Stove options
Duchess
would you suggest that stove over the propane one i have now if i were to stay with this one what i could do is either store the mini propane botles in a sealed cooler that is kept on deck lashed to something or i could convert th stove to be able to be fed by a tank on the rail. I am getting the impression that alcohol doesnt have the power i need, and you say kerosene stoves are of low quality. I am planning on crusing toronto to newfoundland this year then heading for europe via bermuda and after that i will likely head back west to the carribean via bermuda, I am probably going to then work a bit and possibly go on a full circumnavigation slowly. possibly though the first part is for sure.
post #16 of 46 Old 11-13-2013
mitiempo's Avatar
Re: Stove options
If you are happy with the single burner (I think) stove you have you could keep it. I would keep it as a second emergency stove and get a proper 2 burner gimbaled stove with outside tank.
You are planning a lot of travelling, so your priorities should be:
1. Availability of fuel
2. Ease of use
3. cost of fuel
4. efficiency of fuel including cleanliness and heat produced - alcohol vs propane for example
If your current stove is a one burner (not the Coleman but the Forespar) it is rather limiting. A 2 burner stove you can use when sailing (gimbaled) should be the minimum I would think. My stove is a 3 burner gimbaled with full oven with broiler - I regularly use the oven as well as 2 or 3 burners - just like at home, which is what my boat is. Camping is ok for a few days but it wears thin after a while.
Brian
mitiempo is offline
post #17 of 46 Old 11-13-2013
jslade8581's Avatar
Re: Stove options
We have an Origo one-burner on our boat. The non-pressurized alcohol is relatively easy to find and it heats up FAST (much faster than we expected).
S/V Zephyr
1981 O H Rodgers 33
"The cure for anything is salt water - sweat, tears or the sea."
- Isak Dinesen
jslade8581 is offline
post #18 of 46 Old 11-13-2013
casioqv's Avatar
Re: Stove options
Duchess There's currently a gimbaled kerosene stove on ebay, search for "sea swing."
I use an MSR Dragonfly backpacking stove with kerosene on my boat, and love it (although it's not gimbaled). It's far more powerful than any stove (portable or not) I've ever used, and will boil a gigantic pot of water in minutes. Sometimes I run it on regular automotive diesel fuel, which is really cheap. It can also run on gasoline or white gas if I swap out a nozzle.
I think kerosene is the way to go for stoves as it's both safer, and more energy dense (so you burn a lot less fuel). The downside is that they can be a bit smoky when first lighting them, before they warm up.
christian.hess likes this.
casioqv is offline
post #19 of 46 Old 11-13-2013
mitiempo's Avatar
Re: Stove options
Relatively easy to find in North America - but not where the Duchess will be going.
Brian
mitiempo is offline
post #20 of 46 Old 11-13-2013
mitiempo's Avatar
Re: Stove options
As far as fuel use 10 lbs of propane lasts me 6 to 8 weeks cooking aboard every day - I use the oven regularly as well.
There is no "safe fuel" really, if there was it wouldn't burn.
Alcohol is considered by many (including a few long term cruisers I know) as the most dangerous fuel. You often cannot see the flame. One cruiser had a flare-up with an alcohol stove and the water that was put on it just chased the flames under cabinetry - the boat was a total loss.
Brian
mitiempo is offline
Tags
cooking , galley , propane , stove
Big Stove vs. Camp Stove tjgault Provisioning 14 02-06-2013 03:52 AM
Can I use my stove? Harborless General Discussion (sailing related) 3 09-19-2012 04:45 PM
CNG stove captain conrad General Discussion (sailing related) 2 08-17-2011 02:27 PM
CSI CNG Stove to LPG EpicAdventure Gear & Maintenance 5 07-19-2010 10:26 AM
New stove aruggiero Gear & Maintenance 3 07-25-2006 09:14 PM
