Old 10-02-2004
GK GK is offline
GK is on a distinguished road
Durabak deck non-slip coating?
Has anyone experience with this rubberized coating? It seems quite tough http://www.durabak.com/data.htm
This coating is apparently used commercially on ships'' decks and coast guard decks, yet it''s talked about very seldom in cruising circles.
Some first hand accounts would be helpful.
Cheers,
Duncan
Old 10-02-2004
Billpjr is on a distinguished road
Several guys reported using the stuff on the iboats web site. One of them coated the entire interior of a Boston Whaler. It sounds like a good product and reported to be very tough. I emailed the factory and they sent a sample which looks and feels to be durable. It is coarse but probably not too bad on bare feet.
Old 10-13-2004
sailnaway is on a distinguished road
Hi people I ran into this product called Sani Tred it sounds the same but it is non toxic and cures with water restauraunt grade stuff used on ships hospitals ect. I think it is www.sani-tred.com
Old 10-13-2004
I went to the site http://www.durabak.com
and I went to http://www.sanitred.com
they seem to be the same product just one claims to be the first but I am not sure maybe people have not used it because they dont want to scuff the boat up with rough paper which is how you make it stick I will give it a try just because I am not into pulling all the screws and rebedding them on the tow rail. Let me know if anyone learns any more about it.
Old 06-24-2010
jschlocker is on a distinguished road
Durabak Used on Leaking Wood Covered Fiberglass Deck
Greetings:
I worried about spending money on Durabak to coat the wood covered fiberglass deck only to have it not stick or look good. I sanded the previously epoxied wood (to try and seal it; didn't work) wiped it with xylene and applied two coats of "brown", looks more red, and touched up a couple of cracks and it looks great! Flexible and firm; looks to have stuck to the old surface very well. I am not sure if I shorted my life breathing xylene, like a dummy without resperator, but so far I am very happy with the results. I plan to use it on the upper deck too and the window frames.
Best of Luck, Jeff
Old 06-24-2010
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Wow! Five years, eight months and eleven days. That could be a record
Welcome to Sailnet, Jeff
Jim
s/v Abracadabra
1976 Pearson P30
Old 06-24-2010
deniseO30's Avatar
Lies about her age
I wonder how it compares to KiwiGrip?
Old 06-24-2010
mitiempo's Avatar
Jim, not a record, I've seen longer.
Brian
Old 06-25-2010
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
I put Durabak on my deck and cockpit 4 years ago. It adheres well and has great non-skid properties.
The one thing that I am not satisfied with is that it is impossible to keep clean. I made the mistake of using white on the cockpit sole. It quickly became a dirty grey and looks worse than any mildewed gel coat I have ever seen. I've used stiff brushes, chemicals, and every cleaning product available and it still looks like crap. I gave up and covered it with a grate. Don't use white!!
The tan deck is not so bad; there are some pretty bad stains that won't come out. The stains are just dirt, not chemical. I actually recoated the deck last year to cover over the stains.
I might try Kiwigrip in a year or two if it doesn't require a complete stripping of the Durabak.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Deck coating LDH Gear & Maintenance 1 09-24-2005 12:38 PM
Crackling deck on an ericson-27 marcberoz Boat Review and Purchase Forum 0 01-04-2004 03:02 AM
