Confused about prop pitch, variance between prop brands - Page 5 - SailNet Community
 1Likes
post #41 of 41 Old 11-25-2013 Thread Starter
no longer reading SailNet
Alex W's Avatar
Re: Confused about prop pitch, variance between prop brands
Edson's installation manuals say a stop is required to avoid damaging the main steering cog, so I will put one back in. My stops are made of aluminum angle extrusion and it looks like flipping them will give the intended amount of travel. I sort of wonder if they were just installed backwards at the factory.
I'm going to do a quick haul to install the prop. It is cheaper than hiring a diver and easier than doing it myself while diving (I'm scuba certified by have no experience working on boats underwater). Quick haul is about $150 for one hour of having the boat hang in the slings, while the most commonly hired diver in my marina wanted $450 regardless of prop model. Featherstream prop installation is done with the prop intact (instead of in pieces like the Max-Prop) so I should be able to keep it under one hour, and have time to change my zincs.
Alex W is offline
Islander 30 MK II Prop Pitch johnyjackson Islander 11 11-11-2011 05:02 PM
Max-prop pitch settings johnharch Pacific Seacraft 11 03-06-2010 09:47 AM
Max Prop pitch adjustment ereiss Gear & Maintenance 15 03-07-2009 01:59 AM
caliber 40 prop pitch janders Caliber 1 08-25-2008 06:30 PM
Sabre 38 Prop Pitch Sabreman Gear & Maintenance 8 06-10-2008 10:37 PM
