aluminum diesel tank - SailNet Community
post #1 of 3 Old 10-04-2004 Thread Starter
I am getting ready to install an aluminum diesel tank, and of course have had many, many passersby throw in their 2 cents worth. Many state I should use a ''for metal epoxy'' paint on the exterior surface after prepping with vinegar, others still say just plain epoxy paint, others feel I should protect the tank with a ''rubber sleeve'' since it will be in close proximity to the batteries, and others state to leave it alone. The manufacturer of the tank says that painting the tank is ''over-rated''. Does anyone have experience with this? Thanks
mary jewell is offline
post #2 of 3 Old 10-04-2004
After about 18 years of use, my aluminum diesel tank corroded through - from the inside out! External corrosion on aluminum mounted below decks is negligible. Don''t worry about it.
maxlynn is offline
post #3 of 3 Old 10-05-2004
Gluv-it. All sides. Period. I replaced an alum. tank that looked like it had been shot with buckshot (motorboat). The new one is protected by Gluv-it. Available hardware stores, boat stores, etc.
VIEXILE is offline
Sealant for aluminum fuel tank rleslie Gear & Maintenance 1 11-11-2004 08:29 PM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 07:26 AM
is diesel fuel compatible with lined tank? johnbonner31 Gear & Maintenance 1 12-27-2002 03:10 AM
aluminum water tank CISCOJOE Gear & Maintenance 4 07-15-2002 07:56 AM
diesel tank inspection/cleanout port creek Gear & Maintenance 0 07-16-2001 03:00 PM
