Need help getting propane fitting off - SailNet Community
 1Likes
post #1 of 12 Old 11-16-2013 Thread Starter
Jiminri's Avatar
I'm trying to get a screwed-on connector off an old propane appliance and I cannot get the connector to budge. It was a connector for the propane line and some type of pipe sealant (looks tan or brown) was used on the threads. What is typically used as a sealant for propane pipe joints? It the answer just more muscle?
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #2 of 12 Old 11-16-2013
Old as Dirt!
svHyLyte's Avatar
Re: Need help getting propane fitting off
Ensure that you are turning in the correct direction. On some old gas appliances, for whatever reason the connection tightened by turning connector counter clock-wise rather than clock-wise. If I recall correctly, that was a connector wherein the gas line threaded into the appliance receptacle rather than over it.
FWIW...
Flybyknight likes this.
svHyLyte is offline
post #3 of 12 Old 11-16-2013
Usually/often if a fitting is reverse thread there's a 'notch' in the nut like so:
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
svHyLyte (11-16-2013)
post #4 of 12 Old 11-16-2013 Thread Starter
Jiminri's Avatar
Here's a pic of the brass fitting that I'm trying to get off the appliance. It is screwed onto (what appears to be) aluminum or other white metal part of the appliance. You can see the sealant on the threads. Hard to get a purchase on both pieces to exert some force. (Also afraid of breaking off the aluminum part of the appliance.)
West River, MD
Jiminri is offline
post #5 of 12 Old 11-16-2013
overbored's Avatar
if there is no propane in the system then you can heat the fitting up and it will loosen a lot easier. some pipe dope has a setting agent in it that glues the fitting on and the heat will break down the glue
"GOLD RUSH" PRINDLE 16
overbored is offline
post #6 of 12 Old 11-16-2013
Hmm.. that looks like a standard NPT to flare fitting adaptor.. unlikely it's reverse thread. Do you have a pipe wrench small enough to support the aluminum/potmetal fitting while you try to loosen the brass part? Heating things up with a small propane/butane torch might work wonders if you can safely do that. Concentrate on the brass part.
Drag a dental pick around the exposed part of the threads to see if you can determine what direction will turn it off...
post #7 of 12 Old 11-16-2013
jppp's Avatar
Please no flame. ever. use another form of heat if your going to try that.
1985 C&C 35 MK 3
jppp is offline
post #8 of 12 Old 11-16-2013
Old enough to know better
Are you trying to save the appliance or the fitting? That may determine the course of action, though if it is the fitting, I would say just replace it unless it is very unique.
miatapaul is online now
post #9 of 12 Old 11-16-2013
Old as Dirt!
svHyLyte's Avatar
That does look like a right hand thread. From the yellow coloring it appears that yellow gas-line tape may have been used on the fitting but it also appears that some kind of putty may also have been applied. Have you tried applying heat to the brass fixture only? It may expand enough to make breaking the bond a bit easier. On a worst case basis, you might use a dremel tool to cut off the threaded end and then score either side of the fitting and then use a frozen nut splitter to crack the fitting which should loosen it enough to remove without goofing up the threads on your appliance.
Good luck!
svHyLyte is offline
post #10 of 12 Old 11-16-2013 Thread Starter
Jiminri's Avatar
Just trying to get the fitting off and do not much care if it gets destroyed in the process. Trying not to damage the appliance. A friend wants the appliance and it would fit perfectly in the box I have except for the darn fitting.
West River, MD
Jiminri is offline
Retro fitting a propane locker in a small sail boat downeast450 Gear & Maintenance 47 05-25-2016 05:13 PM
What is this fitting? davidpm Gear & Maintenance 12 05-06-2010 05:16 PM
Name that fitting... cghubbell Gear & Maintenance 12 08-28-2009 08:13 AM
stem fitting genephares Gear & Maintenance 0 03-10-2006 11:23 AM
