Old 10-12-2004
Stormer_2003 is on a distinguished road
Head Plumbing
I need to replace the hose in my head configuration.
Has anyone used solid PVC piping? I have heard that it is very odor resistent and has to be way less expensive than the $8 per foot they charge for the Sealand Odor Safe flexible hose...
Has anyone had experience (good/bad) with the black sanitation flexible hose? Seems a lot cheaper.
Thanks.
Old 10-12-2004
hamiam is on a distinguished road
Head Plumbing
i would think that pvc piping would be too rigid for application in a sail boat where you can experience both hull flexing and changes in temperature. If you are having stinky head problems the lines are only one aspect of the problem. I replaced my lines and still had the same stink. You might want to try a product called "potty potion" in your holding tank; it has worked for me. Also, there is an excellent article out there by a woman nicknamed the "head mistress" which explains why the head is stinky and how to get rid of the stink. (Hint: it has to do with getting fresh air to the bacertia in the holding tank.)
Old 10-24-2004
pjfsail is on a distinguished road
Head Plumbing
Sailnet sells 1 1/2" Trident waste hose for $3.82 per foot. Why not buy from the folks who provide us with this forum for free? Regards, Peter
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 03:00 PM
What''s the best toilet (head) and... Myblueheaven Cruising & Liveaboard Forum 2 10-04-2003 09:52 AM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 12:23 PM
Rudder head corrosion aflanigan Gear & Maintenance 3 01-27-2003 01:01 AM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 07:26 PM
