window replacements - SailNet Community
post #1 of 3 Old 11-16-2013 Thread Starter
window replacements
I have a 1976 Morgan out island sailboat. The original ports have been replaced. Apparently the old ports were cut out and smoked lexan or plexiglass was cut to size and screwed on from the outside. There are 3 rectangle pieces on each side. Over the years they have cracked and I would like to replace them. Previous owner said he used the wrong material and because of heat and exposure and flexing of the boat they have cracked. What material should I use to replace them so this does not happen again?
jasonr575 is offline
post #2 of 3 Old 11-17-2013
billyruffn's Avatar
Re: window replacements
Talk to Select Plastics. I've found them to be both knowledgable and helpful.
Select Plastics, LLC: Marine Hatch Repair
billyruffn is offline
post #3 of 3 Old 11-17-2013
Ideally cast acrylic.. Bedding with DC795 works well, don't be afraid to use the darkest "smoked" material. It will look clear from inside and let in plenty of light, yet afford privacy during daylight (but be equally transparent from outside looking in at night!)
Drill oversized holes for fasteners if you use them, or you can glue them down with the DC795.. Allow a sealant bed thickness to allow for different expansion rates between f/g and the lenses.
Search the forum.. Plenty of discussion on this.
Faster is offline
Replacements for old instruments? Dave_E Gear & Maintenance 6 08-19-2013 07:20 PM
Looking for window replacements for 22'USY empaynejr General Discussion (sailing related) 0 07-08-2009 03:17 AM
navigation light bulb replacements Jmac62 Electrical Systems 1 03-23-2009 11:02 AM
Port hole replacements syon Gear & Maintenance 15 06-09-2008 02:29 AM
CAL 22 Hatch Glide Replacements Yagermeister Cal 0 07-22-2007 04:37 PM
