Blogs
User Name
  #11 (permalink)
Old 11-02-2004
Billpjr Billpjr is offline
Billpjr is on a distinguished road
portable propane stove
Gord,
I don''t trust noses 100%. The reason is I was visiting friends on a 40'' Newporter (while anchored)and smelled propane...they didn''t smell it. We soap checked the tanks (properly mounted on the aft deck in boxes vented overboard) and found a leak. It was backdrafting down the companionway into the cabin. I think they were used to smelling propane and I wasn''t. They were smokers, it scared me for propane use.
  #12 (permalink)
Old 11-02-2004
jkumin jkumin is offline
jkumin is on a distinguished road
It''s about acceptable risk. Many boaters have gasoline engines, and gas fumes pose risk, sharing many characteristics with propane. One difference is the gasoline is theoretically contained unless there is a leak. Propane is free to enter the boat if the flame goes out on a cheap burner without a flame sensor.
If you decide the risk is acceptable at least get a good propane detector. We have one connected to the solenoid. Once someone spilled a glass of wine and we noticed a while later the oven had gone out. The vino fumes tripped the detector / solenoid. This incident also points out the problem of relying on devices like alarms. The solenoid tripped but the alarm didn''t sound, although when tested later it was working fine.
Keep in mind we are all capable of brain fade. A friend with a Cal 2-27 and an Atomic 4 spilled gas and started the engine without getting it thoroughly cleaned up. The boom was heard for miles.
Display Modes
vB code is On
Big Stove vs. Camp Stove tjgault Provisioning 2 07-16-2004 01:23 PM
Need info on Pearson 30 alcohol stove pilot2sailor Gear & Maintenance 3 01-08-2004 01:01 PM
propane fuel canisters oneprcnt General Discussion (sailing related) 10 02-15-2003 08:45 PM
conversion gas stove? nauticalrich General Discussion (sailing related) 7 02-27-2002 05:17 PM
Availibility of propane davejean Cruising 5 12-04-2000 04:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
