Ranger 23 Keel Wobble Advice - Page 3 - SailNet Community
 8Likes
post #21 of 29 Old 11-21-2013
christian.hess's Avatar
Re: Ranger 23 Keel Wobble Advice
here is my take on it...definetly DONT have to listen or whatever...
I had this exact same scenario on my Islander excalibur 26
the excalibur 26 was ahead of its day back in the 60s, in fact it was the little sister to the cal 40, another LIGHT displacement boat in its day...
when I redid the rigging on my excalibur I took the boat back to my dock and almost had a heart attack when I got off the boat(unrigged)
this is an important point
the keel on the excalibur 26 is deep, thin and quite big...
when I would walk on the side decks I coul not only feel the keel wobble but the bilges would move and creek...in other words the floor boards where either getting moved side to side...or up and down...depending on how extreme the angle was...
so I had a friend move aroound on the boat and I could see the whole bilge and keel move laterally!
I got so freaked out I did nothing for like a month...
sooooo I called one of the best surveyors in town...he took notice of it...then said RIG THE BOAT
step the mast and tension rig CORRECTLY per lapworth specs...
and guess what?
all movement gone
what happens is the thin (light displacement for that time fiberglass work) simply softens up a bit...
my boat had no keel bolts, basically the keel is hanging...the glass just works over 40 years and its not as stiff as it used to be...
I know this can seem as heresy but that does NOT mean your keel will fall off, with keel bolts even less....
just make sure yours bolts and nuts are up to spec and torque and take some test sails with correct rigging tension...
again this is just some advice to take doesnt mean it its exactly what you have going on but...take it with a grain if salt if you will...
if you do want to fix the flexiness there are a number of ways to do so...layup in the bilges and stringers...or even on the outside...etc...
remeber however that some fixes have adverse effects...too stiff here you crack somewhere else, to loose here and something gives...stiff and stronger is not ALWAYS better...there is a happy medium...
good luck
mikulash and lillia28 like this.
christian.hess is offline
post #22 of 29 Old 11-21-2013
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
Sounds like a man who knows what he is talking about.
As Yogi said
In theory, theory and practice are the same thing.
In practice, they aren't.
lou
christian.hess likes this.
lillia28 is offline
post #23 of 29 Old 11-21-2013
truer words have never been spoken...(the part about yogi, not me! jajaja)
man!!!
good stuff lillia28
post #24 of 29 Old 11-21-2013
Aha! Thanks for revealing the the secret to Leon Hillman's much vaunted racing success, the wobbly keel. I'm in the market for a hot boat but Yachtworld.com doesn't support a "wobbly keel" search.
Hudsonian is offline
post #25 of 29 Old 11-21-2013
Another resource for this question may be found over on the cruising forum of sailing anarchy. I recall a guy who goes by memopad has a ranger with the same problem and posted about his experience. Boomer is on the same forum and had a lot of time on Rangers too.
baboon is offline
post #26 of 29 Old 11-21-2013 Thread Starter
This is some interesting advice. I must admit that I didn't think about the rigging. I do tend to run the rigging pretty tight, however, it is worth checking into. I will also double check the keel bolts this weekend. Also this boat has a deck stepped mast. The step on the R23 is on a solid fiberglass beam, (not cored with wood)
Harmonic, any pictures of the work that you did? It sounds like what I have been considering. I grew up doing glass work, however, I am thinking of that as a last resort.
markdthorne is offline
post #27 of 29 Old 11-22-2013
Captain Obvious
Sal Paradise's Avatar
I'm not a naval architect, but I am an architect and I do bit of structural design. If in fact your hull is flexing transverse about the keel and you find nothing obviously loose or broken, and you decide to repair it yourself - you do not want to creat a short ( or narrow) , stiff repair. That could propogate a crack right where the stiff repair ends. You want to spread the bending moment out port to starboard and allow the keel bending moment to be spread until the stress is low enough to be transferred into the original hull evenly. That means the repair is going to be wider.
Faster and christian.hess like this.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #28 of 29 Old 11-23-2013
exactly sal...
post #29 of 29 Old 11-23-2013 Thread Starter
Sal, I understand what you are saying. I have a few things to check into:
First: Keel Bolt Tension (although I think it is OK)
Second: check the Rigging Tension.
Third: Assess how much flexing to too much (this is the tough part).
Forth: Assess the integrity of the existing fiberglass (may require a moisture meter).
Fifth: After I have checked into the above items, determine if I have to reinforce.
Sixth: If I do reinforce, determine flexing needed in the structure (just glass/glass and stringers/appropriate area to grind down and build up)
Seventh: Buy a different boat?
The good news is that I have the winter to figure this out. I do appreciate all of the help that this forum has offered as well as the people who have even offered to take a look! This forum clearly has a great group of people!
Mark
1973 Ranger 26 Keel Bolts Fstbttms Ranger 2 09-30-2016 02:40 PM
Ranger 23 Keel Wobble Advice markdthorne Ranger 0 11-15-2013 09:34 AM
Catalina 22 Swing Keel wobble FlyingScot255 Gear & Maintenance 8 09-16-2012 11:54 AM
Ranger 29, keel flexing? flo617 Gear & Maintenance 2 05-05-2010 09:15 PM
Ranger 23 Keel Bolts Torq Specs newuser Gear & Maintenance 2 04-21-2003 08:43 PM
