-   -   S R Mariner (http://www.sailnet.com/forums/gear-maintenance/10719-s-r-mariner.html)
Bawgy 10-31-2004 04:50 AM
S R Mariner
I have an old V-24 with an SR Mariner knot meter . There are attachments for wires on the back but none there . Where might I find and old digram of how these were wired up ?
sailnaway 11-10-2004 08:11 PM
S R Mariner
Sr Mariner is in New York State I cant Find the number right now but you can call them and they are the nicest folks you could hope to run into. Ask them and they will tell you what to hook up and if it can be fixed they will do that to. Still have parts for most units even the old ones.I will try to find the number tomorrow I think you can get it off the net however.
DelmarRey 11-11-2004 07:13 PM
S R Mariner
Here''s their web site:
http://www.srinstruments.com/
smackdaddy 05-14-2010 08:49 PM
78 Attachment(s)
Okay - I've been searching for essentially the same info. SR Mariner no longer makes marine instruments and though they have a section for manual downloads - nothing there.
I have a DDM-1 depth gauge and a DKT-S knotmeter. Both of them are wired and work okay - but I'd like to see if the lights work. There is a single connection screw that's labeled "light". But how do I wire this?
Do I just run a wire from the + connection to the light connection? How is is grounded?
Then, to make it more complicated, should I wire the instrument lights into the running lights circuit so that during the day the instrument lights aren't on and only come on with the running lights?
Surely someone has had enough time to think about this in six years.
Bawgy? Whaddayasay?
mitiempo 05-14-2010 09:12 PM
I'd guess there is already a ground if the instruments work so only a positive is needed. Engine gauges work the same way, only a positive for lighting.
smackdaddy 05-14-2010 09:25 PM
78 Attachment(s)
Cool. Thanks miti. I'll give a try.
