Blogs
User Name
Old 11-01-2004
levenezia levenezia is offline
levenezia is on a distinguished road
backstay adjuster
I recently ordered a new Tartan 3700 which comes standard with a split back stay. My question is, should I order the optional integral split backstay adjuster? I don''t plan to race the boat but may want to adjust the backstay occasionally. I''m not sure if I should add the option. It''s certainly an item that could be easily installed later. What do the experts think?
Old 11-01-2004
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Moderator
Jeff_H will become famous soon enough
backstay adjuster
Absolutely order the backstay adjuster. They are comparatively inexpensive when you think of the cost of the boat. Backstay adjustment is more important on a cruising boat than a race boat. On a race boat you have crew to run around and re-tension halyards and sheets in a gust to balance the helm and reduce heeling. A backstay adjuster allows for a precision adjustment without leaving the helm. You can simply adjust until the helm goes neutral. Obviously it will be less effective in a slightly outdated design like the Tartan 3700 than on a more modern design but it will greatly extend the wind range of the sails without having to reef. It also allows a setup of the rig with less backstay tension except in heavy going which reduces the strains on the boat and improves light air performance.
Old 11-01-2004
thorJ30 thorJ30 is offline
thorJ30 is on a distinguished road
backstay adjuster
definitely
even if your mast wont bend as much, it does make a difference to let air out the top and therfore reduce healing angles ...
Thorsten
J 30
Display Modes
vB code is On
calibrating a backstay adjuster tudmaester General Discussion (sailing related) 1 12-05-2004 10:18 AM
Backstay adjuster for P-30 for racing; C''mon Jeff VIEXILE Buying a Boat 8 03-16-2004 02:57 AM
Stearns Hydraulic Backstay Wburton Gear & Maintenance 4 01-12-2004 12:41 AM
installing a backstay adjuster chris1514 Racing 1 08-19-2003 09:01 AM
backstay adjuster chris1f Racing 15 01-25-2003 12:08 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
