Perkins 4-107 - SailNet Community
Blogs
Old 11-01-2004
tjkassen is on a distinguished road
Perkins 4-107
Have a Perkins 4-107 in an Alberg 37. Engine has about 1800 hrs on a major overhaul. The engine is becoming somewhat hard to start, and is putting out quite a bit of "blue" smoke, and is leaving a slight "sheen" on the water. It seems to run OK and seems to not have lost any power. Could this be a injector pump timing problem? A set of rebuilt injectors did not help the problem. I want to explore any possibilities before we pull the engine. Any ideas are appreciated.
Tom
Old 11-01-2004
WHOOSH is on a distinguished road
Perkins 4-107
Tom, what do the folks at www.alberg37.org/index.htm say? I''m guessing somewhere there is ahead of you on the engine hrs. curve.
Jack
Old 11-02-2004
Billpjr is on a distinguished road
Perkins 4-107
I can''t help the problem but...I lived aboard for 10+ yrs on the ICW in Florida and saw many 4-107s with 3000-5000 hrs and still running perfect. Injector pumps were the normal "major repair".
Perkins 4-108 Heat Exchanger for Sale anaspen General Discussion (sailing related) 0 08-08-2004 10:04 PM
Perkins 4-108 Heat Exchanger for Sale anaspen Gear & Maintenance 0 08-08-2004 10:03 PM
Heat Exchanger (Perkins 4-108 loa36 Gear & Maintenance 1 07-10-2004 11:58 AM
Perkins 4-108 Oil Sump Strainer ABullard Gear & Maintenance 1 04-20-2004 02:00 PM
Perkins 4-108 GeorgeHughes General Discussion (sailing related) 2 05-29-2002 07:21 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
