Blogs
User Name
Old 11-02-2004
bidet bidet is offline
bidet is on a distinguished road
Seacocks- Marelon or Bronze
Our boat has the factory Marelon seacocks, several have become very difficult to open and close. can I replace them with the bronze seacocks or should I stay with the marelon. one guy was telling me about lightning strikes blowing holes in the bottoms with the bronze type. I know the marelon will be less corrosive but the bronze is much cheaper.
Bill
Old 11-02-2004
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enough
A couple of quick points:
Marelon, like bronze, needs to be kept lubricated. There are special lubes for the purpose and with lubrication the valves in question probably do not need replacement.
Bronze thru hulls when bonded can lead to damage to the glass in the vicinty of the thru-hull when struck by lightning.
Good quality bronze fittings are generally substanially more expensive than Marelon. Brass which is not suitable for below waterline use is generally less expensive than Marelon so be careful that you are not looking at Brass instead of bronze fittings.
Old 11-03-2004
Jeff, the Bronze seacocks I mentioned can be found at West Marine. they looked like bronze to me but may be brass castings that are machined. the marelon seacock at West Marine for my seastrainer is $99.00, bronze (or brass) is about $39.00. since I am replacing several the savings could be substantial but not at the cost of safety. I will check on the type of metal.
Thanks
Bill
Sponsored Ad
Display Modes
vB code is On
sealer for bronze port twilk Gear & Maintenance 2 10-28-2003 10:48 AM
Cleaning bronze seacocks walt123 Gear & Maintenance 0 07-25-2002 09:23 AM
Marelon vs. Bronze thinredmohican Gear & Maintenance 20 04-03-2002 08:08 AM
Cape Dory Bronze Portlights WLJarrell General Discussion (sailing related) 5 11-26-2001 09:28 AM
Testing the condition of bronze turnbuckles Sloop23_417 Gear & Maintenance 2 05-04-2001 04:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
