Shaft Alignment: Alignment causes mount problems - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 11-23-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: Shaft Alignment: Alignment causes mount problems
On Guenevere we changed the shaft and prop. I no longer had room for a collar zinc or Perry nut. So I installed a shaft brush on the inside of the boat grounded to a zinc on the outside. It's been working GREAT and it's easy to change when needed.
You can see on at;
ProMariner Shaft Brush
An install image;
Greg
christian.hess likes this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #12 of 13 Old 11-23-2013
How about bolting mounts to a 3/8 plate with longer bolt pattern(elongated holes on forward ends) on the base. Counter bore/weld heads of bolts to plate and re drill beds when aligned.Fill the old holes with epoxy.I usually make a sort of C clamp with a nut welded on so sideways adjustment can be obtained by turning a bolt.Handy on the heavier engines.
Capt Len is offline
post #13 of 13 Old 11-24-2013
snake charmer, cat herder
zeehag's Avatar
we rebuilt the blocks the engine mounts are secured into. as a result of the proper realignment of the engine, my propshaft became neutral and perfectly aligned and no more shaft gland leakage..rodlmao.
so i am no longer trying to make a round hole ovalized.
now for mobility factor......rebuilding engine will be completed at anchor if not before then. we anchor me out mid december.
formosa 41, cruising tropics
zeehag is offline
2GM20F Shaft Alignment... mm2187 Gear & Maintenance 5 04-11-2013 09:29 PM
Shaft alignment with a dripless seal Downunder Gear & Maintenance 6 05-11-2010 03:30 PM
Proper shaft alignment Joshua Dawn Gear & Maintenance 20 12-13-2009 04:17 PM
Engine Alignment Problems HenryTully Gear & Maintenance 17 08-08-2008 09:21 AM
Prop shaft alignment Jotun Gear & Maintenance 9 02-23-2007 10:13 PM
