Shaft Alignment: Alignment causes mount problems - SailNet Community
 1Likes
post #1 of 13 Old 11-22-2013 Thread Starter
In order to achieve good alignment on my Beta Engine and shaft, the flexible engine mount holes are too close to the original holes in the engine bed to provide a good drill and tap solution. My flexible engine mounts provide no elongated bolt hole slots so there is no adjustment built into them. Has anyone else encountered this problem and is there another solution other than buying new engine mounts that have slotted holes?
lizardheadone is offline
post #2 of 13 Old 11-22-2013
Re: Shaft Alignment: Alignment causes mount problems
Assuming you have FRP bunks, i would think that you could glass in the old holes, fair the surface and drill new holes
Hudsonian is offline
post #3 of 13 Old 11-22-2013
A. Fill exsisting holes with epoxy (or appropriate filler) ?
B. Move everything forward or back an inch, would prop still be spaced right ? Maybe a shaft length change ?
C. maybe a spacer to move engine and trans forward a bit?
Just throwing some ideas here, you probably don't need much movement right ?
"Just call me TB"
capttb is offline
post #4 of 13 Old 11-22-2013
Can you create slots in your new mounts with a round file?
Faster is offline
post #5 of 13 Old 11-22-2013
Markwesti's Avatar
I'm with Faster on this. Also if it would be to much to file, a machine shop could elongate the holes and also if need be make a thick washer to help beef up the elongated hole .
Markwesti is offline
post #6 of 13 Old 11-22-2013 Thread Starter
Thanks for the replies. My mounts do not have much usable base to elongate the holes. I thought maybe welding a wider base on the existing to make a wider base in order to elongate the holes. Does anyone see a problem with doing this?
post #7 of 13 Old 11-22-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
When I replaced my engine, I took out the old mounts, drilled the mount holes with a drill the size of a wood dowel I picked up from a hardware store. Epoxied in the dowls, then drilled the holes for the new mounts. I also had a new shaft made to make sure the prop was at the correct distance aft with proper clearance so the cutlass had water lube to it.
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #8 of 13 Old 11-23-2013
Superior Sailor
Squidd's Avatar
Im with Greg on this...overdrill old hole and epoxy in a dowel...use new mounts as designed...drill and tap where you need them.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #9 of 13 Old 11-23-2013
Fisheries Supply has slotted mounts at a reasonable price. You might want to check them out.
ampro is offline
post #10 of 13 Old 11-23-2013
Our (molded) engine beds have a steel plate embedded under the glass to accept the mount bolts.. the drill and dowel trick wouldn't work and a 'slightly offset' hole would be tough to deal with.
Now I'm wondering if there's enough 'room' vis a vis the prop/cutlass/rudder etc to shift the shaft & coupling forward or aft enough to avoid the existing holes and use the mounts as is..? Might need to relocate a shaft zinc or two..
Faster is offline
2GM20F Shaft Alignment... mm2187 Gear & Maintenance 5 04-11-2013 09:29 PM
Shaft alignment with a dripless seal Downunder Gear & Maintenance 6 05-11-2010 03:30 PM
Proper shaft alignment Joshua Dawn Gear & Maintenance 20 12-13-2009 04:17 PM
Engine Alignment Problems HenryTully Gear & Maintenance 17 08-08-2008 09:21 AM
Prop shaft alignment Jotun Gear & Maintenance 9 02-23-2007 10:13 PM
