Fresh water tank quantity indicating - Page 2 - SailNet Community
 14Likes
post #11 of 16 Old 11-23-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: Fresh water tank quantity indicating
Originally Posted by christian.hess View Post
how do those work for water? I always found that for fuel no gauge ever lasted me enough...
having metal tanks I always tapped away to find the level but for water that would be nice if they lasted say 5-10 years?
If your tank is not a box type shape, you need to calibrate the gauge. Our tank is "V" shaped. What I did was start with an empty tank, I then added fuel at 5 gallons at a time. In my log book, I made a page with 6 copies of the gauge face, without the needle on it. After each 5 gallons, I drew in the position of the needle. I now know that when my fuel gauge reads 1/2 full, I have 1/3 of a tank remaining.
Been working very well for quite some time.
Greg
jimgo and christian.hess like this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #12 of 16 Old 11-24-2013 Thread Starter
Dave_E's Avatar
Good Discussion!
I'm going for the verticle tube idea. It's simple, and it works. I'll take pictures when I get it done.
christian.hess likes this.
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #13 of 16 Old 11-24-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by Dave_E View Post
Good Discussion!
David--
Just be sure to have a tight plug on the top end of the tube; or, if you use a inverted U-Shaped tube, that both ends are connected to the discharge line from your tank, in either case to ensure that your pump (hand, foot or electrical) doesn't tend to pull air into you water line from the level guage.
Good luck...
svHyLyte is offline
post #14 of 16 Old 11-24-2013
The vertical tube idea is great, simple solution. If you take it one step further and connect the top of the tube to the vent line (or back to the tank somehow) then there's no fiddling with a plug or any need to worry about pumping action etc.
This is a typical practice in 'gauge glasses' in industry.
Faster is online now
post #15 of 16 Old 11-24-2013
Another very simple solution is a dipstick. I made one for my diesel tank and then calibrated it by adding and marking 50 liters at a time until the tank was full. I have a small stainless steel cap on top of the tank which I unscrew and then just lower my wooden dowel dipstick in to read the level. My water tank is in the keel and at the moment I have no way of knowing the water level. I'm thinking of adding a dipstick there as well.
Faster likes this.
Vindö 50
copacabana is offline
post #16 of 16 Old 11-24-2013
We have the same 'Fuel gauge' .. reliable as anything!
We use more water than fuel, obviously, and enjoy having the continual monitor on our water usage with the Tankwatch setup.
fresh water tank vent deniseO30 Gear & Maintenance 6 06-21-2013 12:02 PM
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 11:03 AM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 04:42 PM
fresh water tank repair averdog Gear & Maintenance 6 09-14-2003 10:50 AM
fresh water tank maintenance wrguest Gear & Maintenance 1 01-07-2002 11:37 AM
