Air Conditioner Hazard Potential - Page 4 - SailNet Community
 3Likes
post #31 of 35 Old 11-26-2013
One of None
deniseO30's Avatar
Re: Air Conditioner Hazard Potential
All I'm seeing is lines drawn in the grou... sand
My last project!
deniseO30 is offline
post #32 of 35 Old 11-26-2013
Maine Sail's Avatar
Originally Posted by SchockT View Post
Either that or the unit isn't grounded properly.
With proper AC grounding this type of short should have tripped OCP..... The sad reality is that the case grounds are very often over looked and omitted. I see this ALL THE TIME with battery chargers, inverters and inverter chargers.. I also see it with AC and heating systems..
On-board AC wiring and grounding are also very often incorrectly installed. The sad reality is that we can't always count on the green grounding wire to get all the way back to land to trip OCP. The AC green to DC Earth/bonding is critically important and this is a potential example of why.....
A "short" like this, if this is what actually happened, should have tripped OCP in fractions of a second....
SchockT likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #33 of 35 Old 11-26-2013
ebs001's Avatar
The fact that it actually didn't trip to me is a further indication that the problem was in the control circuit which is not grounded and therefore will not cause a short to ground.
I would be greatly concerned with any 120 volt installation that was not properly bonded back to the source of power because as I indicated earlier it truly does represent a serious potential hazard.
ebs001 is offline
post #34 of 35 Old 11-26-2013
Maine Sail's Avatar
You would be greatly concerned with about 80% of the boats out there then.....
boatpoker likes this.
______
post #35 of 35 Old 12-22-2013
Dirt Free
boatpoker's Avatar
Only 80%
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
Air conditioner questions saillife Gear & Maintenance 6 08-13-2010 03:49 PM
Paint in the Air Conditioner labestia Gear & Maintenance 3 06-29-2009 10:16 AM
Recommissioning Air Conditioner mgmhead Gear & Maintenance 8 06-10-2009 12:45 AM
Smoke from air conditioner dohenyboy Gear & Maintenance 7 07-29-2007 12:11 AM
Air Conditioner randall2v Gear & Maintenance 0 06-30-2004 02:39 PM
