Blogs
User Name
Old 11-15-2004
rbtpfe9 rbtpfe9 is offline
rbtpfe9 is on a distinguished road
masthead lighting problem
I am completely befuddeled by my masthead light. It won''t work. I have checked current before it goes into the mast and it registers on voltage meter, current registers when I place probes on masthead light but when I insert light it does not burn. Light is good. Also, when masthead lightbulb is removed light illuminating down on deck barely burns but when I put bulb in the deck light goes completely out. Any ideas?
Old 11-15-2004
Light referenced above is my steaming light/deck light combination - have not made up to the top of the mast yet to see why that light doesn''t burn either.
Old 11-16-2004
CherylannJohn CherylannJohn is offline
CherylannJohn is on a distinguished road
In a similar problem, but not on a mast, it turned off to be a faulty ground. Reading with a meter looked like it was a good ground.
Cleaned and reattached all connections from the light to ground and it fixed the problem.
A Guess,
John
Sponsored Ad
Old 11-20-2004
halyardz halyardz is offline
halyardz is on a distinguished road
I had the same problem on my Tartan 33 (52'' mast). It was very frustrating. So last year we pulled the mast and rewired the rascal with two 3-16 feeds...one to masthead where we also installed a tri-color, and other to steaming/deck. The existing wire was totally messed up...bare spots, no logic to connections etc. Works fine now and peace of mind is priceless. Jim
Old 11-20-2004
Edel-665 Edel-665 is offline
Edel-665 is on a distinguished road
I''d take a bit of emery cloth and polish up the contacts on the bulb. As you mentioned, when you put the bulb in another fixture, it fails there also.
HalayrdZ, You netioned that you rewired with 3/16. You realize, you''ve rewired with undersized wire. In order to get the proper 3% voltage drop limit, you should have used 12awg wire. Voltage drop for nav lights (and other critical circuits is to be limited to 3%, which in your situation calls for 12 awg ideally and 14 awg at minimum)
Old 11-20-2004
c25 c25 is offline
c25 is on a distinguished road
Edel,
I was going to mention the same thing (3/16 to small in halyardz''s application), but was rushed when I first saw the post. I just re-wired my 30 foot mast and was on the ragged edge (a bit over) of 16 gauge vs 14 gauge...I went with 14. Another word of advice..don''t rely on the West Marine Catalog wire estimating charts...they''re wrong...actually they don''t have fine enough resolution & this leads to errors. As for wire...Hamilton Marine in Maine had good prices on marine wire in 100'' spools.
Old 11-20-2004
C25,
I don''t use the West Marine catalogue for wire sizing. I use a combination of "Boatowner''s Mechanical and Electrical Manual" and an application called Wiresizer 2.0. It''s a great little app, you can play with the % voltage drop, the gauge, and the reference voltage.
the site for wiresizer seems to be messsed up these days. If you''re interested let me know and I''ll email you the application.
Old 11-21-2004
c25 has got a point...3/14 would be better to run to the masthead and also agree that 100'' or larger spools is the way to go.
Old 11-24-2004
39512 39512 is offline
39512 is on a distinguished road
Sounds like a polarity problem.
Display Modes
vB code is On
Sloop, Cutter or Ketch jsgsail Buying a Boat 17 1 Week Ago 03:47 PM
Fractional vs. Masthead Rig max-on Buying a Boat 7 06-14-2004 02:37 PM
Cell phones and masthead antenna update mikehoyt Gear & Maintenance 6 09-06-2002 07:40 AM
Catalina 34 Starting Battery Problem Garytami Gear & Maintenance 2 06-04-2002 04:42 AM
masthead v. fractional rig aasault Buying a Boat 1 10-05-2001 04:31 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
