Blogs
User Name
Old 11-16-2004
talessi talessi is offline
talessi is on a distinguished road
Mooring Gear
Might have to leave mooring ball, chain and anchor in over winter. Any advice for survival against ice?
TA
Old 11-16-2004
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seņor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
Mooring Gear
We have a marina slip and a mooring but for ice protection I always remove the ball and mooring line from the 3/4" anchor chain for the winter. During a low, slack tide and before disconnecting the ball, I pull the ball onto my tender and shackle a winter float to the top end of the anchor chain. I made the float from a 3" dia x 48" long pvc pipe with both ends glued & capped and my mooring number painted at the top portion.
The pipe is weighted with enough sand to keep it floating vertically. The bottom end is double-capped, enabling a SS through-bolt connection without breaking the inner cap''s watertight seal.
This is not an original idea . . . many boaters use a brightly painted length of wood; I prefer this technique for it''s permanance. Also, make sure you log the anchor location with your GPS . . . just in case. I donned my scuba gear, searched and tagged a friend''s mushroom anchor last Spring after thick ice and an unusually high tide snapped his ball shackle. The pipe has much less resistance.
Steve
Old 11-17-2004
waltward waltward is offline
waltward is on a distinguished road
Mooring Gear
Talessi
Where are you, what water are you in & how far from shore is your mooring? Are you in a solo mooring location or in a mooring field?
Walt --- Northwestern Lower Michigan
Display Modes
vB code is On
Mooring Problems in Paradise HELP!? VIEXILE General Discussion (sailing related) 2 09-01-2004 10:24 AM
mooring NOTACLEW Gear & Maintenance 1 09-04-2003 06:05 PM
Transient mooring in Cape May, NJ? ha.taylor Cruising 2 06-13-2003 01:59 PM
Temp mooring or berthing on East Coast? rogerbohl Cruising 1 02-24-2003 04:53 PM
HELP - Foul Weather Gear REC''s! GlenS General Discussion (sailing related) 3 03-19-2002 09:22 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
