"Modified" Fram Oil Filter - SailNet Community
post #1 of 2 Old 11-29-2004 Thread Starter
During a recent oil change, I found that no oil was circulating past my newly installed Fram PH8A oil filter. This is the same make/model of filter that was "working" on the engine (W60) when I bought it.
However, the "old/working" PH8A filter appears to have been "modified." The brand new PH8A that I tried to put on, has the large center hole (that goes on the nipple) and several smaller holes surrounding it. These small holes don''t appear to allow oil in or out; no flow threw. They have a rubber gasket inside the filter blocking the holes.
The "modified" PH8A appears to have the gasket pushed out of the way of the holes (almost looks like someone just stuck a screw driver inside and moved the rubber ring out of the way.
To make sure I didn''t have just a single defective filter, I tried another brand new PH8A and got the exact same results. No oil flow or pressure.
So here''s my question: Has anyone ever heard of modifications like this??? It gives me the creeps.
Or has anyone heard of a change in design of this particular filter. I''ve been told that it''s been the same for years.
pma_foyl is offline
post #2 of 2 Old 11-30-2004
I have seen some wierd things done to improve oil flow most do not work. I would trash the filter and get a good filter Hastings or a quality filter. I am a dealer for AMSOIL and you can if you wish contact me and I will show you some things that will change the way your engine runs and the length of oil and filter changes. I have a dual Bypass filter on my old Universal Atomic 4 it runs so quiet and cooler with this setup and synthetic oil it is really good stuff. I would like to tell everyone here about this product line but people get ticked off if you use the site for sales. I do not care if you buy it from me or not I got into it for myself and glad I did. This stuff really works. E-mail me if you think I can help you. Thanks Jim
sailnaway is offline
Diesel fuel filter sneuman Gear & Maintenance 1 06-29-2005 05:19 AM
Diesel filtration option? maxim_rfeld Gear & Maintenance 7 10-10-2003 12:52 PM
Modified or true sine wave inverters windancer1 Gear & Maintenance 9 01-29-2003 07:33 AM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 12:41 PM
diesel fuel filter tho52mas Gear & Maintenance 2 05-16-2002 10:26 PM
