Wind Direction Indicator Placement - SailNet Community
post #1 of 6 Old 11-27-2013 Thread Starter
Trying to fit antennae, masthead light and wind direction indicator on mast (such that 15" wind indicator doesn't hit light or antennae). A seemingly easy choice would put the indicator on the aft portion of the masthead assembly (that is set back about 8" from the mast where the back stay is connected). Is there a problem with doing this (disrupted air?)? Not sure I see any photos where others have placed indictors in this location and definitely not a choice mentioned in the indicator's installation material. Looks like a prior owner solved the problem with an extension forward of the mast (which puts the indicator in a location that is difficult to see from the cockpit).
SailNoFo is offline
post #2 of 6 Old 11-27-2013
Re: Wind Direction Indicator Placement
I think you'll be fine there. As you say, if you move it forward the line of sight may be lost.. unless you go up and ahead, as some serious race boats do.
Ours is on the aft end of the masthead fitting, works well. I've even seen people put extensions aft for that to avoid similar obstacles.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
SailNoFo (11-29-2013)
post #3 of 6 Old 11-27-2013
no longer reading SailNet
Alex W's Avatar
Davis makes a version of the Windex that you can mount directly to the antenna. That should work pretty well.
Alex W is offline
post #4 of 6 Old 11-27-2013
Old as Dirt!
svHyLyte's Avatar
Alex is correct. You can kill two birds with one stone for about $35.00 USD:
See http://www.boatersland.com/dav3160.h...FSEV7AodvmkArw
svHyLyte is offline
post #5 of 6 Old 11-29-2013 Thread Starter
Thanks. I'm new at this but thinking things at the top of the mast are best done right the first time. I think that location will work fine.
SailNoFo is offline
post #6 of 6 Old 11-30-2013
paulk's Avatar
See Davis Windex Av Antenna Wind Vane*-*Davis*3160*-*Wind Indicators*-*Sailing*-*Boatersland Marine
Are you sure that isn't a radio direction-finder?
paulk is offline
1960-1970's Wind Direction Indicator CanadaDryGingerAle Gear & Maintenance 1 08-14-2013 05:58 AM
looking for 1970's triangular wind indicator CC386 Gear & Maintenance 5 08-15-2011 02:02 PM
Autohelm Wind indicator help TIKI TIME Gear & Maintenance 5 08-01-2010 11:51 AM
Electronic wind direction indicator countrygent5201 Gear & Maintenance 2 11-24-2009 10:13 AM
Alas, poor Wind Indicator! SEMIJim Gear & Maintenance 20 04-01-2008 03:11 PM
