Blogs
User Name
Old 12-01-2004
GDEMING GDEMING is offline
GDEMING is on a distinguished road
Impeller change 4 a Westerbeke 21
I recently purchased a 1985 Nonsuch 26 with a Westerbeke 21 diesel. What''s the easiest procedure to change the impeller in the fresh water intake pump? There doesn''t seem to be a lot of room.
Old 12-01-2004
Denr Denr is offline
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
The easiest way to change the impeller would be to pull the engine, like it is with my W27. Short of pulling the engine you could remove the pump but that would mean realigning the drive tang of the impeller shaft so you''ll just have to do it like the rest of us, learn to work backwards. I would strongly suggest that you buy a second shaft and have a your spare impeller pre-mounted to exchange it in a flash if required without the need to remove the snap ring to get at the impeller and don''t forget to replace the paper gasket on the cover.
Depending on the age of the pump you might consider rebuilding it which would require that the pump be removed from the engine anyway. A rebuild consists of two plain bearings and two lip seals. Roughly $15 in bits, a new pump costs approximately $300, thanks Westerbeke!
Old 12-02-2004
tonyod tonyod is offline
tonyod is on a distinguished road
I have the same engine in my Niagara 31 and recently changed the impeller. I pulled the whole darn pump off the engine as I lacked the required attributes of a contorsionist to complete the job while the pump remained on the engine.
Sponsored Ad
Old 12-02-2004
WHOOSH WHOOSH is offline
WHOOSH is on a distinguished road
When I last talked to two ace local engine mechanics here in St. Pete, they both told me to just take off the damn water pump and then replace the impeller. I found that the only (tho'' not an easy) option for our W60; for the W71, it''s far easier to remove just the impeller. I think their advice was based on every engine (and its installation) being different and the normal orientation a tradesman has to settle on one workable, routine method and just get good at it for all the obvious reasons.
Jack
Display Modes
vB code is On
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 10:45 AM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 06:15 PM
Sea Water Pump Impeller nauticalrich Gear & Maintenance 3 03-19-2003 09:20 AM
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 2 09-30-2002 06:04 PM
Water Heater Connection Change increased SS top speed 20% MHRitter Gear & Maintenance 0 09-17-2002 04:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
