Sliding gooseneck, does it serve any purpose at all? - Page 2 - SailNet Community
 9Likes
post #11 of 22 Old 12-03-2013
Old as Dirt!
svHyLyte's Avatar
Re: Sliding gooseneck, does it serve any purpose at all?
Originally Posted by PaulinVictoria View Post
I have a downhaul on it already, the problem is that when I release the halyard to reef, the gooseneck slides down then gets stuck so I have to go to the mast to sort it.
I'll try and disassemble it all to try and get it a bit smoother, if it's too far gone then I'll just pin it.
Also, I have a rigid vang so a fixed gooseneck is advised I think?
Add a track pin on the Goose neck track to prevent the assembly sliding down enough to become "stuck". When reefing, remember to free the vang before slacking the halyard. The Goose neck down-haul should be arranged so that it can be easily released/adjusted when necessary from the cockpit (typically a cam-cleat on a multi-part block) and remember to ease that with the vang release. The type vang is irrelevant. Of course, if you are simply looking for a rationale/permission to fix the Goose neck, you have it. Just ensure that your method for doing so is reversible. The next owner may prefer the original design. (Remember. One never really "owns" a yacht but merely has temporary custody for some greater, or lesser, period. Think of later custodians.)
svHyLyte is offline
post #12 of 22 Old 12-03-2013
I think a rigid vang could be adding a 'binding factor' to all of this as the boom can't really drop 'straight down', instead pivoting to a degree on the vang attachment point.
oysterman23 likes this.
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
oysterman23 (12-04-2013)
post #13 of 22 Old 12-03-2013
Chastened
Ajax_MD's Avatar
Ah yes, I didn't know you had a rigid vang. That might bind things up, I'm not really sure. Try lubing it all with Mclube/Sailkote first.
Pinning the gooseneck at the minimum desired height is also a good idea. I understand what you're saying about difficulty reefing. I also have to juggle the boom a bit when I reef.
S/V Old Shoes
1973 Pearson 30 #255
Ajax_MD is offline
post #14 of 22 Old 12-03-2013
Paul,
I have the same setup as you on a '76 Pearson. However I think I see in one of your photos that you have the main halyard running to the cockpit, where as I go to the mast to raise or reef the main. If that is so, then I would consider a total reworking of the gooseneck, vang and topping lift to modernize the setup for in-cockpit control of all sail setting functions.
Also, I found that a friction sail stop is not dependable for holding up the boom and sail. It will slide down over time. A screw set in the track will do the job of keeping the boom from sliding down yet is easily removable.
Let us know and see how you resolve this.
John
ccriders is offline
post #15 of 22 Old 12-03-2013
Old as Dirt!
svHyLyte's Avatar
The boom pivoting around the point of attachment of the vang will limit the range of travel of the Goose neck at the mast as the distance between the Goose Neck and Vang attachment point is fixed. Accordingly, the benefit of the floating Goose neck may be obviated.
svHyLyte is offline
post #16 of 22 Old 12-03-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
All my lines (well, the ones I use) are led aft. The rigid vang does allow the gooseneck to slide freely, I think part of the problem though is that as the gooseneck slides down, so the end of the boom lifts up, giving a lovely full sail shape again, not ideal. Seems with the gooseneck being able to move that it just adds another set of complexity to the reefing process, something I like to try and avoid since I almost exclusively singlehand.
I don't know, I'll have a mess around with it and see if I can make the system work, maybe a couple of sail stoppers 6" below the top gooseneck position will give me the usefulness of the sliding gooseneck without the pain of it dropping right down.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #17 of 22 Old 12-03-2013
As Hylyte pointed out, Paul.. it's likely that the rotation of the boom around the vang attachment makes this all a moot point, and you'd be better off with the gooseneck pinned.
post #18 of 22 Old 12-03-2013
mitiempo's Avatar
If you have a solid vang I can't see how it could be effective with a sliding gooseneck, as long as that gooseneck is allowed to move.
Brian
mitiempo is offline
post #19 of 22 Old 12-03-2013 Thread Starter
The vang can change length so the sliding can work for a small amount of movement, as the gooseneck comes down the vang shortens. Problem is when it reaches the limit of vang compression, it basically becomes a fixed pivot point and up goes the end of the boom. I have a feeling I'll end up pinning the gooseneck somehow.
Orange Crush
1974 C&C27 MkII
post #20 of 22 Old 12-04-2013
Old as Dirt!
svHyLyte's Avatar
After pondering the geometry of an archetypal rigid vang (e.g. Garhaurer), it seems evident that with such equipment, a fixed gooseneck is preferable as Brian and Faster suggest. A floating boom could work but repeatedly tuning the geometry for variation in the length of the vang would require rather more effort than the benefit conferred compared with the simplicity of a fixed boom and Cunningham. The Garhaurer, as an example relies on fixed dimensions between the gooseneck and the point of connection of the variable strut on the boom; and, the point of connection near the base of the mast. With these dimensions fixed, the varying the length of the strut dictates the vertical arc of the point of connection at the boom about the point of connection of the gooseneck to the mast and accordingly, the elevation of the outboard end of the boom above or below the horizontal to effect the shape of the main's leach. The floating boom assembly was a good technology for its objective, albeit rather more complex than a simple Cunningham, and worked well with a simple kicking strap or multi-part vang but unnecessary complicates the later, rigid vang, technology.
Here Homer Nods...
svHyLyte is offline
Looking for Advice on Sliding Gooseneck NobodyOfNaught General Discussion (sailing related) 6 06-30-2013 07:19 PM
sliding gooseneck with vang Barquito Gear & Maintenance 3 02-22-2012 04:26 PM
Sliding Gooseneck SteveA General Discussion (sailing related) 3 04-30-2009 10:46 AM
West Marine.. to server or not to serve sailboy21 General Discussion (sailing related) 3 12-14-2007 10:26 AM
