-   -   chartplotter / fishfinder questions (http://www.sailnet.com/forums/gear-maintenance/10951-chartplotter-fishfinder-questions.html)
BarryL 12-11-2004 05:27 AM
Hello,
I''m in the market for an inexpensive combo chartplotter / fishfinder (for depth meter use only). My budget is $500 or so. I have been doing research and there are many makes and models available.
Screen sizes range from 3.5" to 5". There are both color and monochrome displays. Resolutions range from 240 X 240 to 480 X 480.
Any comments so far?
Particular models I am considering are
Lowrance M68 C S Map
Eagle FishElite 480 and 500C
Garmin GPSMAP 178 and 178C Sounder.
Anything else?
Thanks!
Barry
hilodi 12-13-2004 04:34 AM
This may not be 100% on topic but Practical Sailor did a report on depth sounders/fishfinders about 5/6 (?) years ago that might help you.
Cheers.
catamount 12-16-2004 04:43 AM
Why do you want to get a combo chartplotter/fishfinder if you are only going to use it for a depth sounder? You might be able to get a standalone fishfinder for less. You can get a plain digital readout depthsounder, if all you care about is how deep the water is, for less still.
BarryL 12-16-2004 12:16 PM
Hello,
I want a combo unit because it''s cheaper to buy the combo unit than to purchas a mapping GPS and a separate sounder. The depth sounders are all in the $200 range. The unit I will prbably buy, the Lowrance M68 S MAP, is $399, and has a color display, detailed maps with navaids, AND a depth sounder.
I figure the fish finder part will come in handy when I want to anchor.
What I don''t understand is why people spend $200 for just a depth finder when you can get a basic fishfinder for $100 or so.
Barry
Barry
elhanley 12-31-2004 02:29 PM
Fishfinders use a wider angle beam than sounders, so are less accurate over irregular bottoms.
