Mast base organizer? - Page 2 - SailNet Community
post #11 of 16 Old 12-30-2004
i have a catalina 30 that i am rebuilding the mast.. has anyone taken off the base plate for the mast..
how is it removed
thanks in advance
makcap is offline
post #12 of 16 Old 01-04-2005
DelmarRay
Nice set up!!! How did you attach the base to the deck?
Mike T
E-29
Zephyr
mikes-zephyr is offline
post #13 of 16 Old 01-04-2005
DelmarRey's Avatar
Originally the halfmoon blocks were mounted to the deck with thru bolts. I wanted to add 1 extra block and rearrange them for organizers, so I had to fill all the holes and redrill.
After filling and fareing, I placed the blocks on deck where I wanted them and drew a line around them.
Took measurements and cut out a piece of SS plate the shape of a horseshoe, modified.
Then put the blocks back and marked where the holes go. Drilled the holes in the plate then transfered them thru the deck.
Also put another plate on the inside. After all the holes were drilled in the deck
I placed the inside plate on the underside and transfered the holes.
Then drilled all the holes in the deck overside and filled with epoxy/filler, let cure, then redrilled again using the upper plate.
Finished up the deck with paint, sealed the upper plate and holes with 3M 101. And that''s it.
It was a lot of work, but well worth it. It not only looks better but it''s stronger as well.............._/)
DelmarRey is offline
post #14 of 16 Old 01-04-2005
Geez DelmarRey, nice job!
Quick question; Your organizers & linelocks are all mounted off the deck. Did you glass in these mounts or were they factory? (And what''s the boat?)
cheers,
jcm
palacegrand is offline
post #15 of 16 Old 01-05-2005
Sasha_V's Avatar
Sasha_V is offline
post #16 of 16 Old 01-05-2005
DelmarRey's Avatar
JCM,
I put mahogany risers under the organizers and clutches. Epoxied and fared in the corners with triangular strips with one side having a radius, sanded to a smooth radius and epoxied it all in, sanded again, filled any nicks with epoxy filler, sanded again and painted.
I raised the halyards up off the deck for two reasons! I don''t like that green stuff growing under the lines when not in use, a big problem here in the Pacific NW. And the organizers would have required some special geometry with the angle of the deck, the angle of the organizers combined with the exit height of the halfmoon blocks. Plus there''s less of an opportunity for the halyards to wear the deck paint.
The vessel is an old (79) Choate 40 IOR racer. The gelcoat has seen better days so paint is it''s outer coat now, making it easy to make modifications without worry.
Now, I just need to close in the cockpit and raise the winches. Then she''ll look like a Swan 40. Same hull design.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
